Remote Reservoir Shocks - Page 9 - JeepForum.com
post #121 of 134 Old 09-11-2010, 11:07 AM
TJdualsport
I'd laugh if you had phone calls about me. If they were it was prolly just ur little cult following trying to pat you on the back and lift you back up after all the times I shut you down on this thread. The only mess here is ur non sence you seem to love to start. Prior to that it was a good thread. Now you can be done. Haha
TJdualsport is offline
post #122 of 134 Old 09-11-2010, 07:59 PM
TheMusicMan
You need to stress the amount of work and time it takes to do what you're trying to do, that's all.
No he does not.
TheMusicMan.
TheMusicMan is offline
post #123 of 134 Old 09-12-2010, 12:31 AM
hustler905
^ I dunno, when I put my shocks on I think part of the increase in ride quality came from the shocks, and part from the outboarding.
If you can't weld/DIY, outboarding ain't cheap. Neither is trial-and-error re-valving.
hustler905 is offline
post #124 of 134 Old 09-12-2010, 06:03 AM Thread Starter
JeepRubi04
What are your shocks valved at... Any pics??
JeepRubi04 is offline
post #125 of 134 Old 09-12-2010, 11:15 AM
hustler905
I will see if it's in my packing slip, I don't specifically remember. I am also working on some pics, as soon as I can remember to bring my camera with me when the Jeep is clean!
post #126 of 134 Old 09-12-2010, 02:43 PM
TheMusicMan
The valving should be written on the top or bottom of the shock. My Fox Air-Shocks came with the number written on them.
If they were later revalved by a shop, The shop should have written the valving on the Shock. Any decent Shock shop would write the valving.
TheMusicMan.
post #127 of 134 Old 09-21-2010, 09:13 PM
hustler905
I've heard that if I bolt remote reservoir shocks on, my Jeep can survive this:
YouTube - Jeep Jump - Bumblebee Madness
I kid, I kid ... got that from the "Don't Do This In Your Wrangler" thread.
post #128 of 134 Old 09-22-2010, 01:15 PM Thread Starter
JeepRubi04
Haha maybe if you had some triple bypass shocks! I have a question though...
Early on in the threa mrblaine and crusty recommended for the TJ's to lighten the compression as much as possible and keep the rebound numbers high such as 30/90 or 30/75.. Wouldnt the shocks having such ease of compressing over anything, be easier to bottom out and one would constantly be hitting the bumpstops?
I was just thinking about it and it seems like you would want the compression stiffer to keep from hitting bumpstops but please let me know what you think..
post #129 of 134 Old 09-22-2010, 06:36 PM Thread Starter
JeepRubi04
Oh ya, how tight should the lower bushings be tightened to? I tightened them up to about 80lbs and the bushing was squished a good amount between the washer and the shock eye, almost distorted.. Is there any performance problems with this such as the shocks not working properly, or will it just destroy bushings quicker, or is this normal??
post #130 of 134 Old 09-23-2010, 03:15 AM
gebirgziege
hey, i really hate sliced bread. the best way to eat bread is in roll form! lol
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #131 of 134 Old 09-30-2010, 11:35 AM
hustler905
My valving is 45/45 in the front (and a 4/8 on the compression clicker on the street) and a 30/90 in the back (with a 2/8 on the knob). It feels balanced, and resists body roll well. The rear is outboarded, and I have a Currie Anti-Rock. Front shocks are the stock replacement size. This is a DD.
Here are my thoughts - I am far from Baja, and dial the compression low on the slow and technical trails we have here. The back of the Jeep is empty when on the road - no spare, tire carrier, back seat, or hardtop - just a small 12v air compressor and a couple of little miscellaneous bits. Offroad I pack the usual assortment of spare, tools, etc. With the hard top on, I go another click up.
Critique on valving/setup/suggestions? (Please!)
post #132 of 134 Old 09-30-2010, 10:15 PM Thread Starter
JeepRubi04
Hmm mine are valved at 60/45 for the fronts and 55/70 for the rear which is quite different than your setup.
My front compression is on the high side and sometimes it feels like it pushes the jeep back and forth kinda like a rocking horse, except on speeds bumps for example they soak them up real nice after coming down, while the rear seems to almost bottom out I guess from the lower compression setting.
Overall, my valving is "ok" just because I don't really have anything to base it off of other than my previous crappy shocks. But I'd like to try re-valving them, its just time-consuming and more money
It seems the faster I drive, the better they feel, but the slower I drive, the more I can feel every little imperfection
post #133 of 134 Old 10-28-2010, 12:55 AM
Ulumanati
Blaine or crusty: I know you opted out of replying on this thread, but hopefully you could just help me out with this question cuz it seems that some ppl are not all that up to date with the info they give.. Or anyone who has had good experience with these shocks
If I want to get the compression adjuster on some fox shocks, what would be a good valving setup to be able to adjust the compression from one extreme to another so I can really dial them in? I am not sure if valving them 30/70 fronts and 40/70 rears, will give me a lot of room to adjust the compression since I'd only be adjusting from lets say 0-30, as opposed to 0-65 such as the op has his valved..
Am I correct in thinking this, or is this totally off?
2004 Silver Jeep Rubicon
6" Nth Degree Longarm Kit
Ulumanati is offline
post #134 of 134 Old 10-28-2010, 09:59 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Be aware that the compression adjuster is little more than a needle valve with an orifice that just slows down or speeds up how fast the oil gets pushed around.
I would do the valving you have listed and start there.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
bilstein , rancho , fox , shocks , reservoir , advice
Dual shocks w/ reservoir? Ej132 TJ Wrangler Technical Forum 32 12-24-2009 10:04 PM
anybody running Fox oem shocks w/ remote reservoir? RE Mono-Tube Shock W/ Remote Res? murzi3000 TJ Wrangler Technical Forum 2 10-04-2009 08:08 PM
how do i turn on my remote start/remote unlock? krany TJ Wrangler Technical Forum 18 12-17-2008 04:24 PM
Anybody have Reservoir Shocks (BILSTEIN 5150?) Oman Jeep TJ Wrangler Technical Forum 4 04-18-2008 07:32 PM
Remote Reservoir worth it? RnEmOvr TJ Wrangler Technical Forum 3 08-03-2007 10:32 PM
