Remote Reservoir Shocks - Page 7 - JeepForum.com
post #91 of 134 Old 09-06-2010, 11:22 PM
TJdualsport
jeeprubie04, I use some lube and a vise to pop it out or a hammer if a vise isn't around. it shouldnt damage the bushing. for the metal sleeve i use a deep socket that the same size and punch it out.
here is a picture of my resi on the exhaust side of how its run.
TJdualsport is offline
post #92 of 134 Old 09-07-2010, 12:35 AM Thread Starter
JeepRubi04
Thanks! I tried a ball joint press and it worked wonders.. I don't actually see your exhaust haha, where is it? Did you cut it off? I plan on installing them tomorrow and want to make sure I dont run into any problems.
JeepRubi04 is offline
post #93 of 134 Old 09-07-2010, 09:40 AM
crusty1007
Originally Posted by JeepRubi04 View Post
Alright well I decided to go ahead and give the fox shocks a try and they have already arrived. Problem is... the rear shocks have a bar pin eliminator at the top mount and I need to get rid of it due to the Nth shock shifters. The instructions say to remove the top bpe and replace it with the metal sleeve thats at the bottom of the shock, so...
1. How can I remove the bpe without damaging the rubber bushing?
2. Can I press out the lower metal sleeve with a ball joint press?
Remove the shock shifters.
Trim the rear portion of the spring bucket & mount them in the stock location.
However,
What are your current shock lengths, extended & collapsed?
What is the eye to eye measurement with the coil springs removed & the axle stuffed all the way to the bumpstops?
These will be your limiting factors.
If retaining the AEV relocation mounts, it may throw the lengths off & either limit droop or need more bumpstop to keep from bottoming out the shock.
Click the sig for everything you need to build a JEEP... 805-706-0232
NEW PRODUCTS ADDED DAILY !!!
----> Click and download the new catalog!!!
crusty1007 is offline
post #94 of 134 Old 09-08-2010, 10:39 PM Thread Starter
JeepRubi04
However,
The shock lengths for the front are ext 28 comp 17, rear ext 25 comp 15. I got them valved to: Front 60/45 and rear 55/70. Any comments on the valving?
post #95 of 134 Old 09-08-2010, 11:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I suspect you will find that valving to be a tad stiff on the compression side for the front, but we'll see.
The back should be pretty close and with the adjustment you should be able to do, should be good.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #96 of 134 Old 09-08-2010, 11:30 PM Thread Starter
JeepRubi04
Thanks for chiming in.. Maybe I'm not used to nice shocks after having crappy rs5000's for 2 yrs but these shocks while they soak up bumps and potholes nicely, they feel like a damn teeter totter or rocking chair.
When I slam on brakes I feel jeep rock from back to front a couple times, kinda like it drives when I took off front shocks altogether. Btw, the compression being a bit stiff up front, what consequences does that come with?
post #97 of 134 Old 09-09-2010, 08:30 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's easy to think they are soaking up bumps because you aren't bottoming out. View it another way, how much input is each bump imparting to the body and tossing it around?
Hobbyhorse. It's like driving a rocking horse. Happens when the compression is too high and it pushes the body around too much.
I am Savvy
mrblaine is offline
post #98 of 134 Old 09-09-2010, 09:00 AM
NotURMailman
NotURMailman's Avatar
OK Blaine, I have to ask...
You gave your recomendation for shock valving on a rock crawler. How about a trail rig that sees some pretty hard use and ocassional street time (but not a daily driver).
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #99 of 134 Old 09-09-2010, 09:05 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I had Larry's Unlimited 12" Foxes valved 30-70 for the front and 40-70 for the rear and he really liked it. I didn't get to drive it, so I don't know how to critique it.
I will be valving the ones in mine very similar to see how that really works.
I am Savvy
mrblaine is offline
post #100 of 134 Old 09-09-2010, 09:36 AM
bandit455
any advice on what valving to use bilstein 7100's?
Also is there any reason to go fox over a bilstein? bilsteins seem a bit cheaper
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #101 of 134 Old 09-09-2010, 11:57 AM
NotURMailman
Good... I'll let you test it out before I replace my shocks
post #102 of 134 Old 09-09-2010, 02:31 PM Thread Starter
JeepRubi04
Oh alright thanks for the explanation. Why would they reccomend having the compression higher than the rebound for the front tho, they did the same for Jevon's except he said that his feels really good, not "hobbyhorse" like and his I believe was 55/45 fronts where mine are just a tad stiffer at 60/45..
Please school me, does one size up really make that big of a difference? I could see a difference b/w maybe your other valvig option of 30/70 vs mine but I don't get it.
post #103 of 134 Old 09-09-2010, 03:52 PM
TJeeper
TJeeper's Avatar
Bilstein has a progressive valving for long arm TJs that I used when I purchased mine. On the street I liked them. Stiff but not overly harsh. I have an anti-rock and they help control the leaning in sharp corners. The only problem I have with mine is I took off the rear tire carrier and spare tire, along with swapping out my Kilby GTS with a Savvy one. Now the rear shocks are too stiff, don't want to compress much on normal bumps. One of these days I will get a N2 gauge and see if I can adjust the rears to the lower limit and see if that helps.
As for off road, I don't have enough experience with other high end shocks to compare them with. They work good for me, but I am not an expert.
Patrick
TJeeper is offline
post #104 of 134 Old 09-10-2010, 12:14 AM
TJdualsport
TJeeper i had a similar issue, without my spare it felt too stiff but with the spare i bottom out in the back on the big stuff, I built this tire carrier to keep the spare since my swing carrier started loosening up bad and was in a constant state of smashing in my tail gate.
its worked great so far, has takin some huge hits from friends screwin around and keeps the weight i need back there. I was talking with Jim Frens the other day (ex engineer from Nth degree) and we are both conviced its my rear springs. if i changed those up to a heavier duty coil it would cycle much smoother. what rear springs are you running? if you lightened your springs up it may help. i could be wrong but its just food for thought
post #105 of 134 Old 09-10-2010, 07:33 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Are those tire carriers included when you purchase a set of four Fox Shocks nowadays?
I am Savvy
mrblaine is offline
bilstein , rancho , fox , shocks , reservoir , advice
Dual shocks w/ reservoir? Ej132 TJ Wrangler Technical Forum 32 12-24-2009 09:04 PM
anybody running Fox oem shocks w/ remote reservoir? RE Mono-Tube Shock W/ Remote Res? murzi3000 TJ Wrangler Technical Forum 2 10-04-2009 07:08 PM
how do i turn on my remote start/remote unlock? krany TJ Wrangler Technical Forum 18 12-17-2008 03:24 PM
Anybody have Reservoir Shocks (BILSTEIN 5150?) Oman Jeep TJ Wrangler Technical Forum 4 04-18-2008 06:32 PM
Remote Reservoir worth it? RnEmOvr TJ Wrangler Technical Forum 3 08-03-2007 09:32 PM
