Quantcast Reducing lift with spacer blocks? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Reducing lift with spacer blocks?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 04-27-2009, 01:33 PM   #1
ryan2022
Hi guys, I was talking to one of my muscle car buddies. I have a TJ with a 4" suspension lift. Can I reduce the lift slightly by adding spacer blocks?
I cant see how it would work with our suspension. I dont think theres a body lift as well, but I'll check. We bought it with the lift, maybe I should just suck it up. Its a good kit, and well done.
any thoughts on easy height reduction......other than bricks or sandbags? lol
ryan2022 is offline   Reply With Quote
Old 04-27-2009, 01:35 PM   #2
93jeepyj
I'm pretty sure that would raise it, Maybe he was thinking of a SUA setup with leaf springs? In that application spacer blocks would lower it.
93jeepyj is offline   Reply With Quote
Old 04-27-2009, 01:38 PM   #3
Jeepguy1977
I'm sure your buddy was thinking of a leaf spring suspension where the leaves are mounted UNDER the axle. In that application it would work, but your TJ is coil sprung, so it won't work.
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline   Reply With Quote
Old 04-27-2009, 05:55 PM   #4
ryan2022
YES, I bet thats what he was thinking. Hes an old school muscle car guy. a relaly cool guy, but most of his stuff is leaf spring, or coil fronts. He did mention under the axle springs, which ours arent.
hmm, sandbags it is!
Old 04-27-2009, 06:02 PM   #5
RnEmOvr
Never Forget
RnEmOvr's Avatar
why not find someone to swap springs with? remember sand bags will add weight and reduce your MPG, or if you dont care add armornand look cool while doing it
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Glock Forum
