recommendations Synthetic or Rotella - JeepForum.com
 2Likes
post #1 of 19 Old 08-11-2017, 12:56 PM Thread Starter
HMS
Looking for input on going synthetic oil or Rotella on a new to me 04 Rubicon. Not sure what p.o. used on this 75,000 mile 4.0.
1TrackJack
HMS is offline
post #2 of 19 Old 08-11-2017, 01:06 PM
Kgleiss05
Kgleiss05's Avatar
Me personally, wouldn't switch to synthetic after a motor has been ran thousands of miles with conventional. Just what my dad always told me. I am by no means any kind of expert with oils, just have experience with a 93 Wrangler 4.0, 2004 Rubicon and a 06 Rubicon. Combined over 200,000 miles with nothing but 10w30 valvoline and Napa filters, never had any leaks or issues oil related with any of the jeeps. 3-5k changes always.
06 LJR, Jeep green, hardtop, 6 spd, 3.5" springs, JKS front track bar, RE lower control arms, bilstein shocks.
Kgleiss05 is online now
post #3 of 19 Old 08-11-2017, 01:25 PM
Jeepsr4me
I use walmart brand oil and have a fleet of vehicles in my family.. 3 of the cars have over 150k each.. My truck 180 and 2 newer cars with 118k and 29k and a couple jeeps all over 150k.... ALL on walmart oil... The right weight and filters and change when the light comes on or 5k.. Nothing more. Over thinking oil and willingness to pay for snake oil is a big bonus for those selling that stuff... Me, I go by results.. Oh and I managed a small fleet of 8 half ton chevy trucks all got over 275k miles before we got new ones, blew 12 transmissions up and a few rear ends.. Engines never a issue.. 1000's of hours of idling also...... Changed oil every 14k..... cheap walmart oil..
Jeepsr4me is offline
post #4 of 19 Old 08-11-2017, 01:34 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'm no fan of synthetics either excepting in extreme cold weather conditions like in Alaska, Buffalo NY, North Dakota, Minnesota, etc. where their good low-temp flow characteristics are not in doubt. I use nothing but Valvoline 5W-30 or 10W-30 but would be just as happy using Castrol, Mobil, Havoline, etc. if Valvoline were to disappear tomorrow. Today's conventional multi-weight oils are superb, there's no real benefit to running a synthetic except in those uber-cold conditions. 50+ years of nearly nothing but conventional motor oils in my engines and I've yet to have an engine failure.
Jerry Bransford is online now
post #5 of 19 Old 08-11-2017, 01:39 PM
biffgnar
biffgnar's Avatar
Change it regularly and go with whatever dino oil and filter combo is on special at the parts store when you walk in.
biffgnar is online now
post #6 of 19 Old 08-11-2017, 02:16 PM
Athensdawgs81
I run Rotella 15-40 and change every 4000-5000 miles. Just run good oil and change regularly. I tried synthetic too when I bought it and the lifters were real noisy with it. I also replace a quart of oil with a quart of lucas at every oil change.
TheBoogieman likes this.
Athensdawgs81 is offline
post #7 of 19 Old 08-11-2017, 02:49 PM
Shark_13
Mine drips the least with regular Castrol 10w30. Add a wix filter, done and done.
Shark_13 is offline
post #8 of 19 Old 08-11-2017, 03:07 PM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
The Dollar Store oil works for me. I do use Mopar oil filters from Walmart though.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #9 of 19 Old 08-11-2017, 06:26 PM
Loukaps
Loukaps's Avatar
T5 10w30 here. No problems, not very expensive. Supposed to have more zinc than other oils that is the only reason I run it.
Loukaps is offline
post #10 of 19 Old 08-11-2017, 06:56 PM
TJTurbo
I run 10w30 Mobil One synthetic. I buy the 5 quart jug and then mix the extra 2 quarts of oil I buy 50/50 with a bottle of Lucas Oil ZDDP additive. Refill the empty quart bottles and save the remaining oil in case I need to add a little before the next oil change. The M1 is for the Banks turbo and the ZDDP is for the OPDA. I never have to add oil so I always have the 6th premixed quart on hand for the next oil change. Just pulled my OPDA for inspection and it and the cam gear are looking good.
TJTurbo is offline
post #11 of 19 Old 08-11-2017, 07:37 PM
TJTurbo
I have always heard that but from experience doing so I don't think it's a problem unless you already have a small leak to begin with. Switched mine to synthetic at 88,000 miles now at 99,000 and no leaks. Switched my Harley at 23,000 now at 25,000 no leaks. The synthetic flows better at colder temperatures so maybe that explains why a drip could turn into a puddle.
Kgleiss05 likes this.
TJTurbo is offline
post #12 of 19 Old 08-11-2017, 07:38 PM
Davidgoodman
10-30 Rotella for mine, it seems to like it.
Davidgoodman is offline
post #13 of 19 Old 08-12-2017, 03:32 AM
mrbee63
I have a 2006, 4.0. It had 90k miles when I purchased, no leaks. First oil change I opted for synthetic boom rear main started leaking and making a mess of the garage. I researched online and others have had same issue. Just a word of caution. I agree, that routine oil changes are key no matter what oil you use but would be hesitant to change with that many miles.
Sent from my SM-T560NU using Tapatalk
mrbee63 is offline
post #14 of 19 Old 08-12-2017, 05:45 AM
2jhanna
This for me also, or WalMart's SuperTech. And if on sale, the hi-mileage stuff to help with RMS minor drip. 10/30 BTW.
jhanna
denton county, tx
2jhanna is offline
post #15 of 19 Old 08-12-2017, 05:54 AM
rsurran
Whatever regular oil is on sale at NAPA and a NAPA Gold filter, high mileage formula preferred. 270k Miles, uses no oil between changes.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
