Recommendations for a replacement engine? - JeepForum.com
post #1 of 4 Old 01-14-2011, 02:05 PM Thread Starter
zboy421
I've had my jeep for 3 years now, and this morning, I believe I cracked a piston head, there is a loud ticking noise, and concentrated gray smoke comes out the tailpipe.
I am interested in buying a new or rebuilt engine. Does anyone have any recommendations as to where to go and what to get? Currently it has an inline 4cyl, and I'd like to beef it up to a V6. I am not a motor-head to say the least, and therefore I am very unfamiliar with the process of purchasing and installing a new engine. Are there requirements I should be looking for?
A friend of mine has a totaled 97 Dodge 1500 with a V8 5.7L Magnum, could that engine fit my needs?
I'd greatly appreciate any help....
zboy421 is offline
post #2 of 4 Old 01-14-2011, 02:15 PM
Gonewhln
If you or someone have the know how then yes the 5.7 will fit but there is a lot of work involved.
You should check out this web site further and check Jp magazine for a write up on this and check out www.burnsvilleoffroad.com they have been doing these engine swaps for years.
Gonewhln is offline
post #3 of 4 Old 01-14-2011, 02:26 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Motor swaps with a fuel injected, non-original motor are difficult and time consuming. If you cannot do it yourself, it will cost thousands and can easily reach $10,000 or more.
A '97 Dodge would have a 5.2 or a 5.9.
The 5.7 Hemi in Dodge trucks came along in '02 or '03.
You can fit practically any motor in the TJ engine bay.
Wheelin98TJ is offline
post #4 of 4 Old 01-14-2011, 02:30 PM
Madeoflite
Did you mean 5.2L magnum? I just finished my swap and evan at burnsville offroad knows his stuff. Its a fairly easy swap also
Madeoflite is offline
engine , engine replacement , replacement
Replacement Mirror Recommendations? jbarrett TJ Wrangler Technical Forum 5 12-08-2010 05:23 PM
Replacement Driveshaft Recommendations Prot JK Wrangler Technical Forum 9 01-02-2008 05:59 PM
Replacement Top Recommendations? tj99 TJ Wrangler Technical Forum 17 12-12-2007 01:20 PM
Replacement Carpet recommendations? reg32 TJ Wrangler Technical Forum 17 01-07-2007 03:24 AM
Carpet replacement recommendations? finagler TJ Wrangler Technical Forum 19 03-30-2005 04:15 AM
