Recomended Gear oil for Detroit and ECTED - JeepForum.com
post #1 of 7 Old 08-23-2007, 04:18 PM Thread Starter
01amberfirewv
I got both of these used and am getting ready to have them installed as well as 4.88s and 30spline shafts. What is the recomended gear oil for these lockers/TED's? I know the Detroit uses some type of aditive but I am not sure wht.
33x10.50 BFG MT KM2 on soft 8's , 4.88's Super35, D30ECTED, OME HD, AtoZ rockers, skid plates, custom rear bumper, Champion winch, SYE, Woody shaft, 4.0tb, Rocket parts intake, Magnaflow muffler
01amberfirewv is offline
post #2 of 7 Old 08-23-2007, 06:01 PM
sahara33's
no the detroit doesn't use additives. the clutch operated LSD's do. I don't use anything special on mine so this will be interesting.
sahara33's is offline
post #3 of 7 Old 08-23-2007, 07:27 PM
iismet
I run a TrueTrac in the rear with synthetic gear oil. I am installing an ECTED in a HP 30. Auburn states not to run synthetic lube with the ECTED. They specify 80W90 hypoid gear oil and a friction additive they included with the locker.
Auburn Part Number: 504102
Auburn states use of any other lubricants or additives may cause differential clutch chatter.
iismet is offline
post #4 of 7 Old 08-24-2007, 06:38 AM Thread Starter
01amberfirewv
Cool I'll have to make sure mine came with the additive. I didn't see it but it may be in a small pack or something.
Should I use 75-140 syn for the Detroit?
post #5 of 7 Old 08-24-2007, 07:50 AM
crawl1n
I have been running Coastal 80W-90 in my 9" with a detroit for a couple years now without any problems. I haven't used any additive with it either since it is not required.
97 TJ SE HP44 ARB, 9" Detroit, 5.13, 36x12.5 TSL's, RE 4.5" Superflex, JKS 1.25" BL, Goferit 1" MML
06 Jetta TDI for daily driving duties
crawl1n is offline
post #6 of 7 Old 08-24-2007, 07:54 AM
frankiefire702
Same here. Plane old 80/90 with all my detroits.
06 tj locked on 36's.
frankiefire702 is offline
post #7 of 7 Old 08-27-2007, 12:29 AM
iismet
That is what I am running in mine. Also the book that came with the ECTED
states that Ford or GM friction modifier can also be used.
iismet is offline
Gear oil for Detroit locker? heckel TJ Wrangler Technical Forum 8 12-09-2013 07:16 PM
What is the recomended gear ratio for 36'' tires? tat6398 YJ Wrangler Technical Forum 3 03-29-2009 09:13 PM
auburn gear ected locker will_982 YJ Wrangler Technical Forum 4 10-19-2007 12:27 AM
Auburn Gear Ected install/wiring question? MuddyJeepZJ TJ Wrangler Technical Forum 2 12-02-2005 11:03 AM
Auburn Gear Ected Locker 2KJ33PTJ TJ Wrangler Technical Forum 6 08-08-2005 11:07 AM
