rebuilt engine, need help with connecting wires - JeepForum.com
post #1 of 15 Old 05-10-2011, 05:46 PM Thread Starter
Vici0usX
Just got my engine rebuilt, stuck it back in and having problems figuring out where all the loop connector wires go by the ignition coil and distrbutor. I have 3 wires, one coming from the body of the jeep, looks like a ground, a wire coming fromthe same cable the battery is connected too, and lastly, one cable coming from the same cable mess that connects to the ac condenser??. Anyway, I know one of these cables needs to go to the alternator, but which one. And. What about the other two wires, do any wires connect to the ignition coil? Besides the normal connector.
If anyone could take pictures of t passenger side of their engine, large pictures with closeups on where the wire comes from on the alternator and all grounding like wires on that side would be great. If you know where they go that would Be great too..
.I have a 98. Jeep tj inline 6
Vici0usX is offline
post #2 of 15 Old 05-11-2011, 09:13 AM Thread Starter
Vici0usX
Bump!
Vici0usX is offline
post #3 of 15 Old 05-11-2011, 11:33 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
That's why labeling,bagging and taking pictures are essential for this job.I sent you a PM because of the issue of you needing an "FSM".You should be able to find your info there?Let me know if you did?
GOLENJEEPTJ is offline
post #4 of 15 Old 05-11-2011, 11:43 AM Thread Starter
Vici0usX
Yeah, I did everything but take pictures... feel stupid now. I'm searching now
Vici0usX is offline
post #5 of 15 Old 05-11-2011, 11:50 AM
GOLENJEEPTJ
Did you read my PM?
post #6 of 15 Old 05-11-2011, 12:44 PM Thread Starter
Vici0usX
Okay, I believe I got everything right.. but the jeep cranks over, battery seems okay, I smell fuel but the engine will not start. I'm stuck
Vici0usX is offline
post #7 of 15 Old 05-11-2011, 12:44 PM Thread Starter
Vici0usX
Yeah I read your pm, it worked great, used that for figuring out wiring. I'm pretty sure it's right
Vici0usX is offline
post #8 of 15 Old 05-11-2011, 12:45 PM
GOLENJEEPTJ
Do you have an automatic?You need to fill in your profile.If you have an auto,did you replace the paper spacer on the end of the CKP?
post #9 of 15 Old 05-11-2011, 12:46 PM
GOLENJEEPTJ
CKP= crankshaft positioning sensor.
post #10 of 15 Old 05-11-2011, 03:47 PM Thread Starter
Vici0usX
I have manual tranny and no I didn't do that. I just cleaned itt up alittle bit and connected it. Will not priming the oil pump prevent the engine from starting. Maybe I didn't prime it right? What about the engine being painted, can that cause a bad contact for the grounds?
Vici0usX is offline
post #11 of 15 Old 05-11-2011, 05:30 PM
eweswim
I had the same problem, no start after installing a fresh long block. The distributor rotor has to be in the exact position in the distrbutor. I was one tooth retarded and it would not start. The rotor spins clock wise. It should be just past the number 1 pole on the distributor cap if you have the number one cylinder at Top Dead Center (TDC). I cut a hole in the side of an old cap at number 1 plug wire pole and installed it on the distributor. I was then able to see when I had the rotor in the correct position. It fired right up.
eweswim is offline
post #12 of 15 Old 05-11-2011, 08:18 PM Thread Starter
Vici0usX
I'm gonna take that into consideration as well! Thanks bro
98 TJ 4.0L Blacked out
33x10.5 BFG MT
Vici0usX is offline
post #13 of 15 Old 05-12-2011, 11:41 AM Thread Starter
Vici0usX
Well it's trying to start more now, just backfires, I think I'm still getting the distributor in wrong? I'll try again.
33x10.5 BFG MT
Vici0usX is offline
post #14 of 15 Old 05-12-2011, 11:48 AM
GOLENJEEPTJ
The manual trans is different and no paper spacer is required on CKP.
post #15 of 15 Old 05-12-2011, 02:08 PM Thread Starter
Vici0usX
Thanks Golen, that website lead me to the distributor diagrams and I indexed it perfectly and the engine started. The only problem I am having now is the engine will not idle or the idle is very low. I drove it around for 15 minutes, anything else i should do in particular?
33x10.5 BFG MT
Vici0usX is offline
engine , ground , ignition , wires , wiring
Destroyed engine? Connecting rod? pwcracer TJ Wrangler Technical Forum 4 05-10-2011 07:24 PM
Best route for new or rebuilt engine? TimWilson YJ Wrangler Technical Forum 3 09-22-2010 05:34 PM
rebuilt or used engine in 97 TJ 4.0 V6? toddsigmon TJ Wrangler Technical Forum 4 06-07-2007 07:43 PM
4.2 Rebuilt Engine Help BenWelder YJ Wrangler Technical Forum 4 04-08-2007 05:29 PM
Rebuilt Engine joeyprice TJ Wrangler Technical Forum 3 09-15-2003 11:38 AM
