#1 | |
Rebuilding a stock Trac-Lok?
How easy is it to rebuild a stock Trac-Lok differential? My `00 D44 has nearly 100,000 miles on it and I'm prety sure it's never been rebuilt.
Sure a spoonful of Draino will clean you out, but it will also leave you feeling kind of hollow inside.... |
#2 |
With what little it does, why waste the effort? Cost wise you might enjoy a more functional LS like a true trac. more bite and gear driven, not the clutch packs. No additive required.
04 L J Travel'n Gadget Show KE5PPH |
#3 |
My TJ is a daily driver and I only really need the trac-lok for snow and maybe occasionally a wet boat ramp. Where's a good place to get the clutch pack and does anyone know of a good write-up on how to do it?
#4 |
JEEP FREAK
From the FSM:
DIFFERENTIAL-TRAC-LOK DISASSEMBLY (1) Clamp side gear Holding Fixture 6965 in a vise and position the differential case on the Holding Fixture (Fig. 57). ![]() (2) Remove ring gear if the ring gear is to be replaced. The Trac-lok differential can be serviced with the ring gear installed. (3) Remove the pinion gear mate shaft lock screw (Fig. 58). ![]() (4) Remove pinion gear mate shaft with a drift and hammer (Fig. 59). ![]() (5) Install and lubricate Step Plate C-6960-3 (Fig.60). ![]() (6) Assemble Threaded Adapter C-6960-1 into top side gear. Thread Forcing Screw C-6960-4 into adapter until it becomes centered in adapter plate. (7) Position a small screw driver in slot of Threaded Adapter Disc C-6960-1 (Fig. 61) to prevent adapter from turning. ![]() (8) Install Forcing Screw C-6960-4 and tighten screw to 122 N·m (90 ft. lbs.) maximum to compress Belleville springs in clutch packs (Fig. 62). ![]() (9) With a feeler gauge remove thrust washers from behind the pinion gears (Fig. 63). ![]() (10) Insert Turning Bar C-6960-2 into the pinion mate shaft hole in the case (Fig. 64). ![]() (11) Loosen the Forcing Screw in small increments until the clutch pack tension is relieved and the differential case can be turned using Turning Bar. (12) Rotate differential case until the pinion gears can be removed. (13) Remove pinion gears from differential case. (14) Remove Forcing Screw, Step Plate and Threaded Adapter. (15) Remove top side gear, clutch pack retainer and clutch pack. Keep plates in correct order during removal (Fig. 65). ![]() (16) Remove differential case from the Holding Fixture. Remove side gear, clutch pack retainer and clutch pack. Keep plates in correct order during removal. CLEANING Clean all components in cleaning solvent and dry components with compressed air. INSPECTION Inspect clutch pack plates for wear, scoring or damage. Replace both clutch packs if any one component in either pack is damaged. Inspect side and pinion gears for cracks chips or damage and replace as necessary. Inspect differential case and pinion shaft and replace if worn or damaged. ASSEMBLY NOTE: New Plates and discs with fiber coating (no grooves or lines) must be presoaked in Friction Modifier before assembly. Soak plates and discs for a minimum of 20 minutes. (1) Lubricate components with gear lubricant. (2) Assemble clutch discs into packs and secure disc packs with retaining clips (Fig. 66). NOTE: Dished plate is position with the convex side against the side gear. ![]() (3) Position assembled clutch disc packs on the side gear hubs. (4) Install clutch pack and side gear in the ring gear side of the differential case (Fig. 67).Verify clutch pack retaining clips are in position and seated in the case pockets. See pic in post below. (5) Position the differential case on the Holding Fixture 6965. (6) Install lubricated Step Plate C-6960-3 in lower side gear (Fig. 68). See pic in post below. (7) Install the upper side gear and clutch disc pack (Fig. 68). (8) Hold assembly in position. Insert Threaded Adapter C-6960-1 into top side gear. (9) Install Forcing Screw C-6960-4 and tighten screw to slightly compress clutch disc. (10) Place pinion gears in position in side gears and verify that the pinion mate shaft hole is aligned. (11) Rotate case with Turning Bar C-6960-2 until the pinion mate shaft holes in pinion gears align with holes in case. It may be necessary to slightly tighten the forcing screw in order to install the pinion gears. (12) Tighten forcing screw to 122 N·m (90 ft. lbs.) maximum to compress the Belleville springs. (13) Lubricate and install thrust washers behind pinion gears and align washers with a small screw driver. Insert mate shaft into each pinion gear to verify alignment. (14) Remove Forcing Screw, Step Plate and Threaded Adapter. (15) Install pinion gear mate shaft and align holes in shaft and case. (16) Install pinion mate shaft lock screw finger tight to hold shaft during differential installation. (17) Lubricate all differential components with hypoid gear lubricant.
98 TJ |
#5 |
JEEP FREAK
98 TJ |
#6 |
So you need to reset the gears to replace the clutch pack? Damn that sucks.
#7 | |
JEEP FREAK
The pinion gear will remain in the axle housing so nothing gets disturbed there. With the carrier shims and bearing caps, just note their orientaton and position and reinstall everything the same way it comes out.
98 TJ |
#8 |
Wow! Thanks Wheelin98TJ!
#9 |
There is a tech article on Randy's Ring-n-pinion site that reveals some tips to assemble the Trac-Lok carrier
Trac-Loc Assembly Made Easy
'08 Unlimited Rubicon totally stock '97 Sport Canadian TJ, 4.0L, AX-15, D30/35, 4.10/4.11, Powr-Lok/Trac-Lok, Superwinch EPi 9.0, 2.5" JKS ACOS, DT-3000, 31x10.50-15 Cooper Discoverer STT on black steelies, O-R Fab sport bar, Jeeperman skidz and bumpers |
#10 | |
CODE 4 YJ
Let me get this straight.... Im a newbie so be patient! ![]() I can remove carrier w/ the ring gear (i circled it in the image hahahaha) and it WONT mess with the backlash?
It is better to be tried by 12 than to be carried out by 6.... |
#11 |
What is the expected service life on a trac-loc before it needs this anyway? I've seen one estimate of 50k miles but dunno if that was just one of the nay-sayers.
#12 | ||
JEEP FREAK
You are not changing or moving any shims. The shims for the carrier set backlash. If you put them back in where they originally were, you end up with the same backlash. Quote:
It could last 100k with an easy driver.
98 TJ |
#13 | |
Thanks for the how-to above Printed for future reference. |
#14 |
Txhotrod
I know this is an old thread but I was wondering if anybody knows of where to get the tool that compresses the clutch packs? I've done a seach on the net for those tool numbers but no luck?
JOE |
| Tags |
| rebuilding, stock, trac-loc |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
