Rebuild Kit for a 2000 4.0L - JeepForum.com
post #1 of 3 Old 02-22-2013, 06:55 PM Thread Starter
shadygator
I recently blew the motor up in my 2000 4.0L Wrangler. I actually threw a rod through the block. (I'm getting a motor from junkyard). So a friend of mine wants to rebuild it for me, instead of buying a remanufactured motor from a parts store.
Has anyone done this? Suggestions? He also mentioned working the head, putting a different cam in it too. Honing the block. I guess Im looking for links to websites for the parts. Basically needing to be stirred in the right direction.
Then I was told there are different motors for a 2000 4.0L? Some years won't work with other particular models, years, can someone fill me in on this.
shadygator is offline
post #2 of 3 Old 02-22-2013, 07:14 PM
Kracka00
If you find a nice low mileage 4.0 you may be able to get away with just rebuilding the top end of the motor i. e. valve train, maybe throw in a better performing Cam and some aftermarket rocker arms and push rods to give you a few more untapped ponies (obviously providing the crank/rod bearing clearences are within spec on the donor motor)
However, unless your friend has a flow bench and he REALLY knows how to port and polish heads properly... you may just end up making the cylinder head perform worse than it was stock.
Kracka00 is offline
post #3 of 3 Old 02-22-2013, 10:07 PM
George Dickel
George Dickel's Avatar
Stroke it!
check out jeepstrokers.com
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
4.0 , motor , rebuild kit
