-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Rebuild Kit for a 2000 4.0L (http://www.jeepforum.com/forum/f9/rebuild-kit-2000-4-0l-1483121/)
shadygator 02-22-2013 06:55 PM
I recently blew the motor up in my 2000 4.0L Wrangler. I actually threw a rod through the block. (I'm getting a motor from junkyard). So a friend of mine wants to rebuild it for me, instead of buying a remanufactured motor from a parts store.
Has anyone done this? Suggestions? He also mentioned working the head, putting a different cam in it too. Honing the block. I guess Im looking for links to websites for the parts. Basically needing to be stirred in the right direction.
Then I was told there are different motors for a 2000 4.0L? Some years won't work with other particular models, years, can someone fill me in on this.
Kracka00 02-22-2013 07:14 PM
If you find a nice low mileage 4.0 you may be able to get away with just rebuilding the top end of the motor i. e. valve train, maybe throw in a better performing Cam and some aftermarket rocker arms and push rods to give you a few more untapped ponies (obviously providing the crank/rod bearing clearences are within spec on the donor motor)
However, unless your friend has a flow bench and he REALLY knows how to port and polish heads properly... you may just end up making the cylinder head perform worse than it was stock.
George Dickel 02-22-2013 10:07 PM
Stroke it!
2 Attachment(s)
check out jeepstrokers.com
The time now is 09:26 PM.
