06-17-2012, 01:09 PM
#1
I have looked here: http://www.jeepforum.com/forum/f9/fa...-ratio-615380/ and looked at my rearend and have come to the conclusion that I have 3.07s am I correct according to the pic?
06-17-2012, 02:02 PM
#2
do you know your front ratio? cause if you do its the same.
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
06-17-2012, 02:05 PM
#3
yes u have ****ty 3.07 gears
06-17-2012, 02:55 PM
#4
Thanks guys, the reason for the question is because I have 33s and I am tired of the speedo being off. According to this site http://4x4xplor.com/images/speedo/speedochart00.gif I need a 26 tooth gear, I have a 30 in it now. Does this seem correct?
06-19-2012, 11:57 AM
#5
Farm Wheeler
3.07 gears with 33" tires? I'd be more tired of the pitiful performance I was getting than the speedometer being off.
Keep in mind that free advice can frequently be worth less than you pay for it.
06-19-2012, 12:03 PM
#6
Originally Posted by sladeb
Correct, you will need the 26 tooth gear. But you really need something like 4.11 gears to work with the 33" tires.
06-19-2012, 12:05 PM
#7
Junior Member
x 2. I can't stand my 3.07 gears with 31". Decided to drop some dime on a G2 D44 axle 4.10 gears w Detroit elocker and regear front D30. Can't wait to get my 5th gear back.
06-19-2012, 12:26 PM
#8
Go 4.56 you'll be happyier!
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
06-19-2012, 12:57 PM
#9
33's are a good match for 4.56's. Its night and day different between 4.56 and 3.07...I know this from experience.
Current Jeeps:
99 TJ
98 XJ
07-03-2012, 03:07 PM
#10
from the research i have done, the 4.56s are only available for Dana 30/35s, yet Dana 30/35s start at a 3.73 which makes mine a ????
07-03-2012, 03:12 PM
#11
LETS GO HAWKS!!!
4.56 gears are available in almost any diff, and d30/35 def came with 3.07, 3.73, 4.11, and a rare 4.56
with a 3.07, you will have to swap carriers for 4.56
If you live in the rust belt, PB Blaster is your friend and a torch is irreplaceable
Build Thread
KCCO
07-03-2012, 03:13 PM
#12
JEEP FREAK
The tag is very likely correct, but it wouldn't hurt to use another method in the link from the FAQ to verify the tag is correct.
07-03-2012, 03:31 PM
#13
So a whole rear/front end change to get the 4.56 gears?
07-03-2012, 03:45 PM
#14
JEEP FREAK
No.
You can use your existing axle housings with low ratio carriers that will accept the 4.56 gears.
07-04-2012, 03:40 PM
#15
Originally Posted by Wheelin98TJ
No.
can i use my 3.07 carriers then or do i need to use the carrier ratio closer to the gears i am installing like 3.73 or 4.11?
