Quantcast Rear wiper switch stopped working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear wiper switch stopped working
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 02-09-2010, 12:23 PM   #1
CMEvans79
Last night I went to turn on my rear wiper, it sprayed fluid, but the wiper didnt work ... it was working before I stopped for gas, but when I got back into traffic and needed the rear wiper it didnt work and the switch kinda moves like its loose in the housing. Is there anyway to fix this or has this happened to anyone else? Thanks.
I drive a 99 TJ the wife drives an 06 Grand Cherokee with a HEMI! :D
CMEvans79 is offline   Reply With Quote
Old 02-09-2010, 01:49 PM   #2
Fett
Mechanically Declined
Fett's Avatar
I suggest pulling the switch out and inspecting the contacts. Remove any corrosion, clean and try again. If it still doesn't work then get an ohm meter to check the switch operation. If that checks out then start checking voltages at the switch connector and hard top harness then the wiper.
I can send you connector pin outs if you need them.
99 TJ Sport I64L Manual 31x10.5 RE 3.5" Super Flex 1"BL 3.73 gears w/LockRite in front. Warrior Safari Rack.
"When you honestly believe you can compensate for lack of skill by doubling your efforts, there's no end to what you can't do". www.despair.com
|_
|T|
Fett is offline   Reply With Quote
Old 02-09-2010, 02:49 PM   #3
CMEvans79
I think I might have to replace the switch because its not sitting as snug in the housing as it once was. I havent looked at it yet today, but I have already found a dash piece that has a wiper switch in it and eliminates the ashtray like I have been looking for so double win. Thanks and if I do end up needing the pin outs, I'll let you know, thanks.
Old 02-09-2010, 03:20 PM   #4
gcfishguy
Here's a really good write-up on the switch, why they fail, and how to fix them if you're so inclined...
gcfishguy is offline   Reply With Quote
Old 02-09-2010, 03:42 PM   #5
all_clear
Ahh beat me too it. Agreed... awesome write up and more then likely will help you fix yours.
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 4" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
http://www.jeepforum.com/forum/f22/re-build-ilene-1251802/
all_clear is offline   Reply With Quote
Old 02-09-2010, 03:53 PM   #6
CMEvans79
Thanks guys! That might just save me some $ that I dont have
Old 02-09-2010, 03:57 PM   #7
jeepnmike
I guarantee you thats the problem with yours. I just did mine last week. Be careful when removing the switch!
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline   Reply With Quote
Old 02-09-2010, 04:29 PM   #8
CMEvans79
so you suggest gorilla glue? Cause besides Elmers and wood I also have gorilla.
Old 02-10-2010, 03:46 PM   #9
CMEvans79
I currently have mine on the coffee table and gorilla glue is in the places ... that was the problem Thanks!
Old 02-10-2010, 03:48 PM   #10
jeepnmike
I used a 2 part 5 minute quick cure epoxy on mine. You can find it in any hobby shop and it is very strong.
Glock Forum
