Rear window wiper wiring harness diagram - JeepForum.com
post #1 of 15 Old 09-05-2008, 06:51 PM Thread Starter
doneil2
I just bought a used hardtop for my TJ and with it I got a jeep original wiring harness that has the wiper in it and runs to the front with several plugs on it. It did not come with any directions so can someone direct me to a site where I might be able to see the directions. I would much appreciate it.
Thanks
doneil2 is offline
post #2 of 15 Old 09-05-2008, 07:22 PM
grinwa
grinwa's Avatar
http://www.quadratec.com/products/11190_4X_PG.htm
It has the directions there.
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline
post #3 of 15 Old 09-05-2008, 08:33 PM
durango-bob
2006 WK
I bought that kit and it really made the wiring a lot less work. You could try to do it without the kit, but I would not recommend it. (And I have a MS degree in electronics.) If you really want to try and make your stuff work, then the factory service manual has all the wiring diagrams, pin-outs, and connector locations that you will need.
durango-bob is offline
post #4 of 15 Old 09-05-2008, 11:01 PM
grinwa
grinwa's Avatar
Actually, if you get it from the dealer it is the same price and you don't have to pay shipping. It looks like he has the factory harness, just needs the instructions.
Good luck.
'99 TJ
grinwa is offline
post #5 of 15 Old 09-06-2008, 03:50 PM Thread Starter
doneil2
Thak you very much
This is what I love about the internet. You have just saved me a ton of agrivation with your response. I just want so say thank you very much and you have a wonderful day my friend
doneil2 is offline
post #6 of 15 Old 09-16-2008, 04:28 PM Thread Starter
doneil2
No luck
Ok I ripped my dash out had screws and parts all over the place thinking I had this down pat with the directions in hand. The only problem was it was all pictures wuth no specific directions and I could not find where it plugs in under the dash. I don't have the heated window but I do have the wiper motor so I think I only need one of the plugs plugged in and then the switch of course. Can anyone simplify this for me as usually I can figure this stuff out but am having problems here. Thanx in advance for anyone who can help me on this one.
Later
Dan
P.S. good thing is I only had a few screws and parts left over.
doneil2 is offline
post #7 of 15 Old 09-23-2008, 09:28 AM
mellentine
Awesome set of instructions. I've been looking for this! Thanks.
mellentine is offline
post #8 of 15 Old 09-23-2008, 09:44 AM
grinwa
grinwa's Avatar
What year is your jeep? I might be able to help with some diagrams from my FSM. I could send you some stuff tonight when I get home.
'99 TJ
grinwa is offline
post #9 of 15 Old 09-23-2008, 11:12 AM
wagster11
i was hoping i wouldnt need the kit but it is really complicated to do without one so might break down and buy one... dono tho because i am a college student, only use hardtop half the year, but we...
wagster11 is offline
post #10 of 15 Old 09-24-2008, 12:08 PM Thread Starter
doneil2
Wonderful
My Jeep is a 2000 SE and I would reallyu appreciate it if you could help. Thank you
Dan
doneil2 is offline
post #11 of 15 Old 09-24-2008, 01:51 PM
grinwa
grinwa's Avatar
Dan
I sent you a pm.
'99 TJ
grinwa is offline
post #12 of 15 Old 09-25-2008, 09:22 AM Thread Starter
doneil2
Did not receive
I sent you a pm.
Could you resend I did not receive it. Send to dan555@chartermi.net with dan in the subject line should be good. Thanks
doneil2 is offline
post #13 of 15 Old 09-25-2008, 10:13 AM
grinwa
grinwa's Avatar
I'll Send it tonight when I get home.
'99 TJ
grinwa is offline
post #14 of 15 Old 12-21-2008, 07:20 PM
pjleslie03
My wiring harness is cut right in the middle between the pigtail that runs from inside the Jeep to the wiper motor. Can I not just buy that small section of wire from the stealership or a parts store? $159 seems outrageous to pay.
pjleslie03 is offline
post #15 of 15 Old 12-21-2008, 07:32 PM
US1
Could just add wire to your cut harness, and then buy a male and female plug assembly from any electronics supply store and use
them. You'd only be in it for $10 or so for parts.
Is the harness cut on the Jeep side, or inside the top itself?
The harness kit is for the Jeep side, not the top side.
If on the Jeep side, just buy some wire and order the $60 adapter from JeepsAreUs to plug directly into the top, if you want the factory plug. Or find someone here that did the swap from a pre '03 Jeep to a '03 on up top and get the end plug from them for less.
US1 is offline
Damn dog ate my rear windshield wiper wiring harness!!! with pics badazzelanore JK Wrangler Technical Forum 21 07-15-2009 09:57 PM
What is this wiring harness next to the defrost/rear wiper in my '03 TJ? TheMightyGoat TJ Wrangler Technical Forum 4 07-12-2008 07:13 PM
97-99 rear wiper/defrost harness in a 2000? Wiring help please... oogy-boogy TJ Wrangler Technical Forum 5 11-15-2006 09:43 AM
Rear window defrost and wiper wiring bluejeepguy TJ Wrangler Technical Forum 0 10-08-2006 08:30 PM
