Rear window rattle & Tailgate adjustment
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
I guess there has to be some little annoying thing about every vehicle, and this one has an obnoxious rear window rattle.
Seems as though the tailgate doesn't sit high enough when it is closed. I thought it might be tweaked a bit because of the weight of the spare tire, but is almost perfectly level. When it is closed, it just barely touches the rubber weather stripping. After the first bump in the road, there is enough flex in the body or hard top that the rubber pops out and is now on the outside of the tailgate lip. The hard plastic lip on the window is now free to rattle against the tailgate lip. Apparently this has been happening since the vehicle was new, as there is tiny wear pattern (groove) in the plastic lip on the window. Can the tailgate hinges be adjusted either on the body or on the door? If I could lift the door 1/8th of an inch, things would be golden. Whats the proper procedure for making the adjustments, and how do you get the plastic covers off of the hinges? As a temp fix, I laid a thin piece of stick on weather stripping on the window lip. Seems to have trapped the window in place for now.
#2 |
Is the door level from left to right? I think you could adjust the metal latch on the driver side inside the tub. If you raise it higher, the driver side of the door will sit higher.
Black 2001 Wrangler SE, stats in profile |
#3 |
Jeep
Loosen the 2 nuts at the top of the window (one is behind the wiper cover) and then pull the glass straight down. Re-torque gently or it will shatter.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#4 | |
#5 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
