rear window defrost wiring help - JeepForum.com
post #1 of 8 Old 05-16-2011, 11:00 PM Thread Starter
nottijeep
I purchased a 2000 hard top and the hard top mopar wiring kit. I am in the process of wiring the hard top. I followed directions perfectly up until the last step.
I am on step 41, I installed the blue/green and light blue/white wires into the instrument cluster plug in spots #3 and #4, and then turned the car on. As soon as I click the switch to turn on the rear defrost, the 10a instrument cluster fuse pops. And there is no light on the rear defrost switch indicating it is working.
I read somewhere that the instructions might be wrong and the wires in step 41 should be installed reverse of what it says. I tried that and it does the same thing, pops the fuse.
Any advice?
EDIT: Link to instructions I am using: http://4x4icon.com/offroad/hardtop_i...ions/index.htm
99 TJ SE 2.5L Manual
nottijeep is offline
post #2 of 8 Old 05-17-2011, 09:28 AM Thread Starter
nottijeep
bump
post #3 of 8 Old 05-17-2011, 11:47 AM Thread Starter
nottijeep
help!
post #4 of 8 Old 05-17-2011, 12:55 PM Thread Starter
nottijeep
I have looked everywhere and can't seem to figure out the problem. Can anyone help me figure out the issue?
post #5 of 8 Old 05-17-2011, 04:36 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Did you use the instructions for the 1999 TJ?...
Knuckelhead is offline
post #6 of 8 Old 05-17-2011, 04:44 PM Thread Starter
nottijeep
Hey, thanks for your reply!
The instructions were for 97-99, one spot in the directions said to do different things depending on your year. But from the directions it looks like most jeeps 97-99 are the same.
How do you think I should go about step 41, the one I am stuck on?
post #7 of 8 Old 05-17-2011, 05:29 PM
Knuckelhead
AFSOC Retired
Got a multimeter?...
post #8 of 8 Old 05-17-2011, 05:45 PM Thread Starter
nottijeep
I can get one, how would I use it for step 41?
defrost , hardtop , problem , rear , wiring
Repair Rear Window Defrost tab? Dan-O TJ Wrangler Technical Forum 8 10-01-2014 08:53 PM
Rear window defrost tab broken juggle9 TJ Wrangler Technical Forum 2 09-23-2008 09:19 AM
Rear window defrost and wiper wiring bluejeepguy TJ Wrangler Technical Forum 0 10-08-2006 07:30 PM
Rear window defrost? Schrapnel YJ Wrangler Technical Forum 4 10-12-2005 07:57 AM
Rear window defrost? Freshj YJ Wrangler Technical Forum 5 12-24-2004 01:16 AM
