Rear upper control arm - JeepForum.com
post #1 of 4 Old 03-13-2012, 07:54 PM Thread Starter
Aaron0028
Well my jeeps been making a thump noise whenever I go over bumps for a day so a couple minutes ago I climbed under it to figure out what it was. Turns out my driver side rear upper control arm is not even connected to the axle. Went wheeling last week and I guess the bolt came off.
My question is where can I buy the bushings and the bolts? And could anything bad happen from the control arm not being connected for a few days? It doesn't seem like anything could. Thanks
Aaron0028 is offline
post #2 of 4 Old 03-13-2012, 09:04 PM
TheDragonfly
What kind of upper control arms do you have? Are they stock or Rubicon Express as indicated by your profile ? The bolt should be a 7/16" or a size down in metric if stock
4wd has rubicon express bushings
"It is dangerous to be right when the government is wrong." Voltaire
TheDragonfly is offline
post #3 of 4 Old 03-13-2012, 09:08 PM
jays-tj
When is it enough?
jays-tj's Avatar
Give David at Northridge 4x4 a call. (http://northridge4x4.com/) Im sure he will get you fixed up.
5.5" RELA
NorCal Crawlers W6JLO
jays-tj is offline
post #4 of 4 Old 03-13-2012, 09:28 PM Thread Starter
Aaron0028
Rubicon Express control arms, im gonna hopefully get this done this weekend so i can wheel over spring break
not bad if i drive a bit with it not connected to the axle right?
control arm , control arm bolt
rear sway bar and rear upper control arms Vic99TJ TJ Wrangler Technical Forum 20 06-27-2011 02:26 PM
Rear upper control arm MigueloP TJ Wrangler Technical Forum 12 05-03-2011 12:14 PM
Upper rear control arms Richd1963 TJ Wrangler Technical Forum 22 03-03-2011 10:22 PM
upper rear control arm? gregdean13 TJ Wrangler Technical Forum 8 03-15-2010 06:40 PM
Rear Upper Control Arm Help Please!! TJay TJ Wrangler Technical Forum 5 01-07-2007 03:34 PM
