Rear trackbar with Adj upper arms and a CV shaft
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
I'm trying to figure out if I'm going to run into problems with my rear track bar with the addition of adjustable upper control arms to set the pinion angle with a CV shaft. Can I get away with running a regular trackbar bracket or do I have to use the special one for cv shafts? I have the regular trackbar relocation bracket and would rather not buy a new one but want to be prepared before hand if I'm going to run into problems.
What happens if I run a regular bracket with the cv and adj arms? Any in put is appreciated.
#2 |
i just ran the bracket that came with my kit, its the regular RE rear trakbar bracket.
needing a new rig.... |
#3 |
I would worry about binding issues and gas tank skid clearance issues.
I am using stock trackbar with stock bracket right now and I was able to adjust my pinion angle enough to eliminate vibes while I save up for the rear adjustable track bar and the correct bracket for SYE setup. I also have a Rokman gas tank skid and I was able to push it farther to the rear of the Jeep to add some clearance.
05 Jeep Wrangler 2.4l 4 cylinder 3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT Low Ouput 4-cyl Jeep club member #151 |
#4 |
To be honest, it depends. If you are not going for full flex, you could be ok for a while. It will be close (within about 3/4"), but it will fit. If you go offroad, you may contact your gas tank with the track bar. If you keep your ear to the ground, you can pick up a track bar and bracket for pretty cheap. In my opinion, the new trackbar and bracket is simply the right way to go.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
