Rear Track bar ? should i get the extension bracket or a adjustable track bar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear Track bar ? should i get the extension bracket or a adjustable track bar
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 05-02-2011, 08:20 PM   #1
odyssey017
Ok just bought a front jks adjustable track bar after i lifted 2.5 inch.
Now looking at the rear axel I noticed that my tire looks to be sticking out on the passenger side about a 1/2 to 1 inch further than it does on the driver side.
SO Iv been told i need the relocating bracket for the rear track bar to fix this. looking online all the brackets I found were for 3+ inches of lift. I also hear they are a major pain in the *** to put in. So would I be better/easier off just buying a adjustable track bar that i can fine tune the alignment in with ??
odyssey017 is offline   Reply With Quote
Unread 05-06-2011, 09:57 AM   #2
odyssey017
bump
Unread 05-06-2011, 10:23 AM   #3
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
for 2.5" of lift, the bracket is fine.
you need the relocation bracket either way, or the adjustable track bar will bind on the stock bracket and cause it to rip off.
although, the added stress of the relocation bracket does induce stress into the bracket, it can be reinforced so that the stock mount doesn't become damaged.
weld it all together and reinforce.
Read here:
http://www.jeepforum.com/forum/f9/tr...-bars-1147535/
http://www.jeepforum.com/forum/f9/an...acket-1147395/
http://www.jeepforum.com/forum/f9/re...5/#post6297104
Unlimited04 is offline   Reply With Quote
Unread 05-06-2011, 10:43 AM   #4
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can also drill a new hole in the stock bracket.
Like this:
Wheelin98TJ is offline   Reply With Quote
Unread 05-06-2011, 10:47 AM   #5
reewik
I am pretty sure i have the extension bracket if you want it you can have it... Let me find it and you pay the shipping.
1997 Jeep TJ SE 2.5L
35" MTR's on MT Classics with Simulated Bead Locks
4" OME springs, shocks, and Rokmen CA's with 1.25" body
4.88 gears , 8000 winch, Smittybuilt rear armor, bumper with tire mount.
reewik is offline   Reply With Quote
Unread 05-06-2011, 02:22 PM   #6
odyssey017
^ that would be great if your able to find that bracket! So just double check all I need to do is put this bracket on and Im good to go with the stock track bar?
Unread 05-06-2011, 03:12 PM   #7
Wheelin98TJ
JEEP FREAK
Good to go as long as the stock bracket does not tear off the axle like Unlimited04 mentioned above.
Unread 05-10-2011, 04:55 AM   #8
reewik
Sorry man I could not find it, there is one for sale on this board
Unread 05-10-2011, 08:20 AM   #9
NotmyJK
I've got a relocation bracket off of a Zone lift you can have. Do you get up to Columbus? If you want it just PM me and I'll give you a call.
2000 TJ sport
2007.5 Dodge dually
1972 Kaiser Jeep deuce and a half
2008 JK unlimited (wifes)
2001 Boxster (wifes)
1995 Ford F350 dually flatbed (wifes)
NotmyJK is offline   Reply With Quote
