Rear track bar relocation bracket mounting. Cut hole in tub? - Page 2 - JeepForum.com
post #16 of 21 Old 11-01-2010, 08:22 PM Thread Starter
SolidBrass
Well I've a lot more room back there now that I've proper tools and jacks. set of 6K jacks, impact wrench, and floor jack later and there is much more room to sag the rear with wheels off. (Don't think I could get my big old regular drill in there but lots of room for the angle drill.
SolidBrass is offline
post #17 of 21 Old 11-01-2010, 09:13 PM
mudb8
want it rite or rite now?
mudb8's Avatar
an adjustable track bar will still require the OME or like relocation bracket to prevent the track bar from prying the bracket off the axle. I couldn't even beging to tell how many I've fixed or how many people will argue about it.
JKS rear adjustable shown....
any shock longer than stock requires the use of at least 1.25" rear bumpstop extensions, which is the amount needed to prevent the bracket from hitting the tub.
an angle drill is not needed with the shocks and track bar end unbolted, the axle hangs plently low.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #18 of 21 Old 10-11-2012, 05:34 PM
raj111983
Originally Posted by SolidBrass View Post
I ordered this... 18 Volt 3/8" Cordless Right Angle Drill
should do the job... hope hope
I am having the issue as you did in the past to drill a hole in the top of relocation bracket. Were you ever able to drill that hole with angled drill? How did you do this? Did you take off the coil spring? Thanks in advance
raj111983 is offline
post #19 of 21 Old 10-11-2012, 07:34 PM
tommyduncan
I cured my DW by replacing a bent rear lCA. I don't think a trackbar would cause enough problems though?
tommyduncan is offline
post #20 of 21 Old 10-11-2012, 10:32 PM
IslandTJ
Now Jeeping in Oregon
IslandTJ is offline
post #21 of 21 Old 10-11-2012, 10:40 PM
Patrick H
I just jacked up the rear and supported it by the frame. Cordless Dewalt, regular bit fit in there fine without disconnecting anything. 2" BDS springs, 1.25" body lift.
'01 TJ
'48 CJ2A
Patrick H is offline
track bar , rear , trac bar , bracket , bent , broken , fix , replace , replacing , help
Currie Rear track bar relocation bracket play taftech TJ Wrangler Technical Forum 14 01-22-2010 10:48 AM
rear track bar relocation bracket danceswithglock TJ Wrangler Technical Forum 4 07-25-2007 05:16 PM
Rear track bar or relocation bracket BCJEEP TJ Wrangler Technical Forum 1 06-24-2007 10:31 PM
Best value in a track bar relocation bracket? Rear relocation bracket? STW TJ Wrangler Technical Forum 9 02-26-2007 07:58 AM
Rear track bar relocation bracket Spiderman TJ Wrangler Technical Forum 16 02-16-2005 09:00 PM
