Rear track bar question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear track bar question
ZONE 4.25" combo lift for TJ available at Rockridge4wNew Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition Coi
Unread 04-12-2015, 04:48 PM   #1
Groove508
Just put in a rear track bar relocation bracket. There are two rubber hoses at the axle end, do they go under or over the track bar? I did not look before I unbolted it. Btw, the thicker of the two is connected to a block that has the brake line routing from it, what is it?
Groove508 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2015, 08:25 AM   #2
biffgnar
biffgnar's Avatar
Cycle your suspension and run the hoses such that they you don't have an interference problem. As long as no interference there is no magic to how they are run. The one you specifically mention is your brakeline. The soft line is the flexible connection from the hard line on the frame to the hard line on the axle.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 04-13-2015, 09:23 AM   #3
bparsel
2011 JK Wrangler
I just installed a relocation bracket Friday Night. Mine went over the bar.
bparsel is offline   Reply With Quote Quick reply to this message
Unread 04-13-2015, 12:45 PM   #4
Groove508
why does that line run from the rear axle to above the gas tank if its a soft brake line?
Unread 04-13-2015, 12:47 PM   #5
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That's a vent hose for the axle housing.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 04-13-2015, 12:52 PM   #6
biffgnar
biffgnar's Avatar
Sorry, forgot the vent comes through the middle of that block. It is completely closed there. Just a round hole in middle of the block for mounting.
