rear track bar extension?.. or not? - JeepForum.com
post #1 of 8 Old 10-27-2006, 01:56 PM Thread Starter
suicide
I am installing a JKS rear track bar, it is adjustable from 0 to 2.5 inches, so do I need the OME track bar tower? I am thinking "Yes" since the the track bar will be at the end of it's adjustment (OME HD kit).
What do you guys think?
suicide is offline
post #2 of 8 Old 10-28-2006, 04:48 AM Thread Starter
suicide
bump
suicide is offline
post #3 of 8 Old 11-02-2006, 03:56 PM
lupinsea
lupinsea's Avatar
I would think NO.
With a 2" lift myself my axle is only pulled 1/4" out of alignment (left to right). This translates into a measured differences of 1/2" from one side to the other. I'd think that JKS's trackbar would give plenty of lenth to center your axle, even at full adjustment.
I installed a trackbar extension bracket for the rear axle and wish I didn't. It pushed the trackbar up enough to interfere with the gas tank skid and I'm uncomfortable with the added leverage it puts on the stock bracket (though it's probably fine). The bracket extension is coming off an an adjustable trackbar installed probably this coming spring.
- Jay
lupinsea is offline
post #4 of 8 Old 11-02-2006, 04:09 PM
rob5059MOD
rob5059MOD's Avatar
No, you will not need the bracket. It will fit fine and have room for adjustments.
07 JK Rubicon
SOLD 06 Wrangler Unlimited Khaki, Congo Cage, D30 w/Aussie & D44 w/ Limited slip and 3.73 gears, 231HD transfer case with 2LOW and JB Conversions SYE with a Tom Woods DS. LIFT: Full Traction 4" Ultimate lift and JKS BL, Brown Dog MML. SKIDS: Jeep Medic TT and Oil Pan, Warn Gas Tank, and Rusty's Steering Box & Radiator. STEERING: ZJ steering, and PCS Steering Box. Running on 35" BF Goodrich Mud Terrains. And to ruin the look, I added Warn 6" flares to keep it legal.
rob5059MOD is offline
post #5 of 8 Old 11-02-2006, 04:39 PM
06rubicon
2017 JK Wrangler
I have a 2" lift +1 1/4" poly spacers in front on an 06 rubicon, I removed the track bars front and rear and modified them to the proper length. The front was just a heat and bend job, the rear was cut and weld 3/16 of an inch longer.
06rubicon is offline
post #6 of 8 Old 11-02-2006, 09:37 PM
Border Dave
Got Sand?
Border Dave's Avatar
Since I can't search this forum anymore, here's a link to an appropriate discussion: http://www.jeepsunlimited.com/forums...d.php?t=645235
Border Dave is offline
post #7 of 8 Old 11-03-2006, 01:09 AM Thread Starter
suicide
Thanks everybody.
I think I will go ahead and get those BPE's from JKS too.
Jim
suicide is offline
post #8 of 8 Old 11-03-2006, 06:08 AM
blacktjsport
I have a rear trackbar question. If I have ~4" of suspension lift and an SYE, will I need the RE CV rear trackbar bracket and an adjustable trackbar or can I run with only 1 of the above? If I can safely run only 1 of the above choices, which is the best option to use? Why do most kits only come with the bracket and not the adj. trackbar? Thanks,
-Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
Rear shock extension; FYI richs347 TJ Wrangler Technical Forum 0 01-25-2008 06:51 PM
Rear Shock Extension - Mini How-to instg8tor YJ Wrangler Technical Forum 3 05-18-2007 05:58 PM
Rear Track bar Extension Bracket missing bolt Frank the Tank TJ Wrangler Technical Forum 4 08-22-2006 01:23 AM
Rear Light extension goosevodka TJ Wrangler Technical Forum 3 12-27-2005 10:12 AM
rear extension housing... broke again...! Wingmaster YJ Wrangler Technical Forum 4 04-13-2005 12:49 PM
