Rear Tow Hook installation - JeepForum.com
post #1 of 9 Old 02-27-2008, 09:30 AM Thread Starter
breckboarder55
I bought 2 rear tow hooks from Quadratec and just got them in...
http://www.quadratec.com/products/12107_04.htm
I figured it would bolt to the frame but the crappy directions make it sound like it is supposed to bolt to the bumper...
Any body have any picks, or write ups on how to install these?
Thanks in advance,
Adam
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #2 of 9 Old 02-27-2008, 09:50 AM
BlackBellamy
BlackBellamy's Avatar
You should return those.
This is the tow hook(s) you want.
http://www.stu-offroad.com/guards/gas/tj_hooks.htm
Or you can get a regular stock towhook - just search ebay for "wrangler rear tow hook" and get one like this http://cgi.ebay.com/ebaymotors/JEEP-...spagenameZWDVW
The stock hook has an advantage in that there's no extra drilling, and it's horizontal, so less pressure on the mounting bolts. However, some say it sticks out a bit and kills that super-extreme departure angle.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #3 of 9 Old 02-27-2008, 10:09 AM
ASUsax
Another advantage of the Stock tow hook is that if a Chevy Conversion van rear-ends you on that side, that Stock hook will totally F up the van without doing any damage to the Jeep.
Seriously, the stock hook is STOUT.
Blue Jeep Club Member #197
'02 TJ - 33" BFG MT's's, some armor, yadda yadda. 2" BDS lift/1"BL
'94 ZJ - May it rest in pieces.
ASUsax is offline
post #4 of 9 Old 02-27-2008, 10:56 AM
M2LJ
I did the mod from Stu's web site and it was great! (and cheap!) Only thing, some recommend only drilling through one side of the fame rail. I drilled all the way through it, but I think it will still work.
Cheers! M2
M2LJ is offline
post #5 of 9 Old 02-27-2008, 11:01 AM
2005X
i use the stock hook like that one in the ebay add. all i have to say is that hook has saved my *** many of times. i cant tellyou how many times i came off a ledge and hit the hook instead of the bumper, or backed up on a trail and hit the hook which kept me from hitting the bumper. ive hit this thing so hard that it bent upwards which would have destroyed my bumper. just my $.02
2005X is offline
post #6 of 9 Old 02-27-2008, 11:04 AM
BYuen
BYuen's Avatar
I think the stock tow hook is nice. I guess it does kind of hamper the departure clearance of the drivers rear corner... like an inch... I don't mind it. Sort of protects the rear bumper a bit. I can tell you the hook hasn't prevented me from not being able to make it up or down any obstacle It's sturdy I've yanked plenty of others out of the mud pit.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #7 of 9 Old 02-27-2008, 11:11 AM
h2oskikrazy
I bought one of those too. It does mount to the bumper using existing holes with no drilling. Trouble is, mounted to bumper in that location, I think a good
hard pull would bend the bumper. I guess one could drill holes into the frame and mount it like Stu's hook, but the design of the hook makes for less than
desirable access.
I ended up buying one of the factory tow hooks off Ebay.
h2oskikrazy is offline
post #8 of 9 Old 02-27-2008, 12:27 PM Thread Starter
breckboarder55
So no one uses these?
Damn, I have a trip this weekend and had planned on putting these in...
01 Honda S2000DD
post #9 of 9 Old 02-27-2008, 12:30 PM
Dravintoad
Dravintoad's Avatar
You should be able to bolt those in the same location as shown in stu's link. No drilling
See if they line up with the holes already in the frame.
Nothing to see here.
Move along.
Dravintoad is offline
Stock Rear Tow Hook Installation 2008redrockjk TJ Wrangler Technical Forum 7 10-18-2009 02:06 PM
tj front hook installation rc_007 TJ Wrangler Technical Forum 2 12-25-2008 07:26 PM
stock rear tow hook installation on '97 2008redrockjk TJ Wrangler Technical Forum 11 08-18-2005 04:47 AM
Front OEM Style Tow Hook Installation JPWrangler TJ Wrangler Technical Forum 7 08-15-2005 10:09 AM
Took hook installation questions mrparrothead TJ Wrangler Technical Forum 9 06-25-2004 01:28 PM
