Rear tire cupping - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear tire cupping
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 06-22-2006, 05:30 PM   #1
Dudewayne
Rear tire cupping
I have a tire that is cupping on the inside on the passenger side ?
What would cause this and would an alignment help this?
Duane
'97 TJ Sport 5 Speed Soft Top and Half Doors, Sliders
Rubicon Spings and Shocks and 31x10.50's
Dreaded 3.07's GONE !! NEW 3.73's !! Front Dana 30 Rear Dana 35
Red Jeep Club Member #350
"I DON'T SUFFER FROM INSANITY....I ENJOY EVERY MINUTE OF IT !!!
Dudewayne is offline   Reply With Quote
Unread 06-22-2006, 05:41 PM   #2
sbninja
Duane
-wheel balance
- improper inflation
- worn shocks
- worn springs
Make sure you rotate your tires, keep them properly inflated and balanced.
it's the front passenger side, right?
I would think that if it was due to alignment, it might cup both front tires, I could be wrong.
Get new shocks , if you need them.
2004 Jeep Wrangler Sport - Black
WARN steering box skid,Nth degree Oil pan skid
RE 3.5" - M.O.R.E. 1" BL - M.O.R.E. 1" MML
15x8 Tech1 Rock Crawlers (4.5" BS)
35"x12.50x15 Dunlop Radial Mud Rovers
Aussie locked 30/ Ultimate 35 kit w/detroit
Black Jeep Club v2.0 Member #49
See Jeep Here
And here
sbninja is offline   Reply With Quote
Unread 06-22-2006, 06:53 PM   #3
Dragonmaster
Cupping is caused by overinflation (center of tire wearing down prematurely). If it is wearing uneven i.e. inside edge of tire wearing, outside edge fine, then it's probably one of the above mentioned things other than tire inflation, and/or a failed or severly worn ball joint.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline   Reply With Quote
