Rear swaybar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear swaybar
The Original 3/8" Ruffstuff Diff Cover!Offset Tie Rod Kit From RuffStuff!Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 10-03-2014, 10:23 AM   #1
SkeeterTZX
Rear swaybar
Is everybody still running a rear swaybar? I'm going to do disconnects in the front but I know when I ran my XJ a lot of folks just took the rear off.
SkeeterTZX is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 10:26 AM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You want to leave the rear.
TJs having coils in the rear makes it quite different than something with leafs.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 12:11 PM   #3
joe_jeep
There is no reason to remove it.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 03:39 PM   #4
durango-bob
I find that it helps significantly to leave it on in all road and off road conditions. If you run with the front disconnected while off road, having the rear connected makes the Jeep much more predictable when you get into side to side tipping conditions - the Jeep will follow the rear axle in most cases.
durango-bob is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 11:47 PM   #5
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Leave it on, it does more good than you'd guess both on and off road.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 10-06-2014, 08:50 PM   #6
SkeeterTZX
got it. still new to this rear coil spring business
