rear sway bar...keep or pitch? - JeepForum.com
post #1 of 9 Old 06-27-2013, 01:27 AM Thread Starter
flys_yj
I am helping a neighborhood kid install a 4" lift on his 04 tj-x. rear way bar, keep or pitch?
flys_yj is offline
post #2 of 9 Old 06-27-2013, 01:53 AM
Benderff
Benderff's Avatar
Keep it on the Jeep.
Benderff is offline
post #3 of 9 Old 06-27-2013, 06:11 AM
JBTJ
Does no good not to have it, only helps to have it.
JBTJ is offline
post #4 of 9 Old 06-27-2013, 06:57 AM
meatlord
Maximum Disaster
meatlord's Avatar
Pitch it........
Then put an Antirock in the rear.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is offline
post #5 of 9 Old 06-27-2013, 06:59 AM
NotURMailman
NotURMailman's Avatar
I tried unhooking it offroad after reading everyone say there is no reason to do so. I didn't like it.
There was absolutely no useful gain in flex and it fealt creepy on off camber side hills. I just did it as an experiment, because I like to see things for myself rather than just accept what I read online. But from my experience, there is no real gain from not having it, and there are certainly draw backs.
I will be installing a rear AntiRok when I do the outboard and rear coil correction, but until then the OE rear sway bar will be staying in place (with the height appropriate extended links).
As a matter of fact I broke the rear sway bar while running home made extended links (a little while after my little experiment), and I went out and found a stock take off to replace it with.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 9 Old 06-27-2013, 07:16 AM Thread Starter
flys_yj
thanks all..keep!
flys_yj is offline
post #7 of 9 Old 06-27-2013, 07:40 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Keep and live, pitch and die.
RnEmOvr is offline
post #8 of 9 Old 06-27-2013, 08:28 AM
jeepmutiny
1983 CJ7
That falls.under the old liability issue, if he rolls it the first thing that will happen is you will find yourself in court. I would leave it and.make.him sign a release for.the.modifications performed.as I am sure you do not have insurance or a ASE certification....Jon
jeepmutiny is offline
post #9 of 9 Old 06-27-2013, 08:29 AM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
nice, the worms didn't get dirt everywhere after that can opened.
SEMPER FI
LifeProof is offline
