-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   rear sway bar...keep or pitch? (http://www.jeepforum.com/forum/f9/rear-sway-bar-keep-pitch-1541909/)
flys_yj 06-27-2013 02:27 AM
I am helping a neighborhood kid install a 4" lift on his 04 tj-x. rear way bar, keep or pitch?
Benderff 06-27-2013 02:53 AM
Keep it on the Jeep.
JBTJ 06-27-2013 07:11 AM
Does no good not to have it, only helps to have it. :thumbsup:
meatlord 06-27-2013 07:57 AM
Pitch it........
Then put an Antirock in the rear. :D
NotURMailman 06-27-2013 07:59 AM
I tried unhooking it offroad after reading everyone say there is no reason to do so. I didn't like it.
There was absolutely no useful gain in flex and it fealt creepy on off camber side hills. I just did it as an experiment, because I like to see things for myself rather than just accept what I read online. But from my experience, there is no real gain from not having it, and there are certainly draw backs.
I will be installing a rear AntiRok when I do the outboard and rear coil correction, but until then the OE rear sway bar will be staying in place (with the height appropriate extended links).
As a matter of fact I broke the rear sway bar while running home made extended links (a little while after my little experiment), and I went out and found a stock take off to replace it with.
flys_yj 06-27-2013 08:16 AM
thanks all..keep!
RnEmOvr 06-27-2013 08:40 AM
Keep and live, pitch and die.
jeepmutiny 06-27-2013 09:28 AM
That falls.under the old liability issue, if he rolls it the first thing that will happen is you will find yourself in court. I would leave it and.make.him sign a release for.the.modifications performed.as I am sure you do not have insurance or a ASE certification....Jon
LifeProof 06-27-2013 09:29 AM
nice, the worms didn't get dirt everywhere after that can opened.
The time now is 09:01 PM.
