rear sway bar extended links - JeepForum.com
post #1 of 3 Old 07-06-2008, 08:20 PM Thread Starter
safarimike
The jeep feels a bit tippy off road, and its highway manners are really annoying. I am going to re install the rear sway bar. I took it off when it was lifted because I never bought new links, but I want to see if this will help with stability. I don't need quick disconnect ones.
What kind of links are available? What kind would you recommend?
Looking for extended ones that would fit for about 4 inches of lift.
Will the factory sway bar work with the 8.8? I have the R.E. bracket kit which has the brackets for the sway bar, but just wondering with the change in axle, will it still work.
I don't have the original hardware besides the bolt that holds the links to the bar, anyone know what size hardware I would need. I seem to remember a special tab on the frame side to keep the nut from spinning.
1999 Jeep Wrangler Sport
safarimike is offline
post #2 of 3 Old 07-07-2008, 11:01 AM
robncar
robncar's Avatar
Yep, it's a good idea to get that rear bar hooked up.
I'd call RE about what length link to use with the 8.8". I have the RE rear links on my 5.5" kit.
Here's what I found as to Jeep parts for '99:
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 3 Old 07-07-2008, 11:04 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The stock swaybar will work.
You can move the brackets up a little on the axle housing so you have enough clearance for the bigger 8.8 pumpkin.
Wheelin98TJ is offline
Extended Rear Swaybar Links Needed for OME? kubwa_jim JK Wrangler Technical Forum 5 02-02-2010 08:26 PM
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 01:18 PM
Sway Bar Extended End Links DixiesCJ3B TJ Wrangler Technical Forum 1 02-19-2008 12:55 PM
Rear extended Sway Bar links... CHRRRIS TJ Wrangler Technical Forum 7 04-22-2007 02:40 PM
Extended front sway bar links newbomb TJ Wrangler Technical Forum 5 09-04-2005 09:10 PM
