Rear Skyjacker Hydro 7000 shocks feel bouncy - JeepForum.com
post #1 of 8 Old 07-21-2010, 12:32 PM Thread Starter
yinzerr8
Hey all, basic question;
I've got a 0" lift 2006 TJ ~ 55k miles. I decided it was time to change out the blown out stock shocks with a new set of Skyjacker's Hydros due to the $35 rebate offer they were having & quadratec was pimping a couple months ago.
Anyways, front install went well, stupid PA winters ensured that a can of PB Blaster was well used to soak in everything, when it came to the back, despite liberal amounts I snapped a bolt off on the driver side rear. The passenger rear went on without issue, I had to drill out the driver side rear and dropped down two bolts to replace the broken bolt.
In any event, I've been noticing that the ride in the front is fantastic, but in the rear it feels like I'm jumping all over the place whenever I hit a bump, almost like the spring is the only thing holding me down.
At first I thought it might be due me maybe mounting the shock upside down? However looking @ Quadratec's product page, I have the rear's mounted & lined up in a similar manner (tube facing the top)
Any Ideas?
yinzerr8 is offline
post #2 of 8 Old 07-21-2010, 01:25 PM
mdm
Farm Wheeler
Originally Posted by yinzerr8 View Post
...I have the rear's mounted & lined up in a similar manner (tube facing the top) ...
What does this mean? Is the can on the top or bottom? It must be on the bottom or that shock won't work properly.
Welcome to the forum.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 8 Old 07-21-2010, 01:27 PM Thread Starter
yinzerr8
The can is on the top . . . crap.
Looks like I know what I'm doing tonight!
Thanks
yinzerr8 is offline
post #4 of 8 Old 07-21-2010, 01:28 PM
MNakaChunks
I have the hydros and feel the same way: happy with the front, but the rear end feels like it gets some air going over small bumps in the road (MI roads suck so some aren't all that small of bumps). Mine are mounted with the can at the axle end. I would like to hear other people's thoughts on this as well.
- Michael -
MNakaChunks is offline
post #5 of 8 Old 07-21-2010, 09:32 PM
nigel502
a
nigel502 is offline
post #6 of 8 Old 07-21-2010, 09:47 PM Thread Starter
yinzerr8
Man o' Man, do shocks sure work better when mounted in the right direction.
I took the rear's off, fought with the bushings then reinstalled with the can on the top - the bushing on the top. . . . I'd attach a picture but apparently my entry level account doesn't allow it.
In any event - thanks for the help!
yinzerr8 is offline
post #7 of 8 Old 07-21-2010, 10:28 PM
jonesy02
My Hydro's are really bouncy too, can is down. Although i'm not 100% sure its the shock, last wheeling trip I drove home at like 19/20 psi in rear and like 150lbs of stuff in the back and it felt good.
For the street I was running 25 psi in rear and it was bouncy, at 23 now and its a little better, I feel like i'm too low though. Guess I need to chalk test it though.
2006 Unlimited
jonesy02 is offline
post #8 of 8 Old 09-29-2010, 07:59 PM
johnny9
ive had mine 2 months and they are crap and feel like only the spring is working..i called skyjunker and they said it could be mounted upside down so i did..im thinking if trying the other way but cant see it makeing a diffrence now
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
shock , suspension , replacement , skyjacker , hydro 7000 , bouncy
Skyjacker Hydro 7000 yinzerr8 TJ Wrangler Technical Forum 3 09-28-2010 12:06 PM
Hydro 7000 shocks piston up or down? 05WK98TJ TJ Wrangler Technical Forum 4 06-05-2010 03:19 PM
skyjacker hydro shocks stevo328 TJ Wrangler Technical Forum 11 07-06-2006 10:02 PM
Skyjacker Hydro Shocks vs Rubicon Express Twin Tube Shocks jbpdog TJ Wrangler Technical Forum 8 06-13-2006 10:52 PM
OME and skyjacker 7000 hydro 05darkness TJ Wrangler Technical Forum 6 05-19-2006 02:38 PM
