Rear Shocks Upper Bolts Broken.... What to do - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear Shocks Upper Bolts Broken.... What to do
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Memorial Day Sale at Under Cover Fabworks! 15% Discount o
Unread 03-01-2010, 05:34 AM   #1
greta
Hi,
Tried to replace the shocks yesterday. Front went on really easy. The rear had 3 out of 4 upper bolts snap/break. WTF??? I spent about three hours trying to drill out one of the three broken bolts. Got pretty far but never made it. Broke about 5 or 6 drill bits. Amazing how the head of the bolt can be such a POS and the length of the bolt can be undefeatable. Anyway, what can I do from here? Are there any secret techniques to fixing this or just keep on, keeping on?
greta is offline   Reply With Quote
Unread 03-01-2010, 05:43 AM   #2
dualtjs
2011 JK Wrangler
Drill them out, use a dremel type tool to cut them off, big screw drive & BFH or air hammer are the most successful methods. Many people, who don't have a 1" BL loosen the tub bolts and lift it an inch or so to get better access to the nuts to cut them off.
dualtjs is offline   Reply With Quote
Unread 03-01-2010, 05:48 AM   #3
99TJtommy
Originally Posted by dualtjs View Post
Drill them out, use a dremel type tool to cut them off, big screw drive & BFH or air hammer are the most successful method. Many people, who don't have a 1" BL loosen the tub bolts and lift it an inch or so to get better access to the nuts to cut them off.
Thats what i had to do. Have fun.
99TJtommy is offline   Reply With Quote
Unread 03-01-2010, 06:34 AM   #4
greta
any special type of drill bit to use? like i said, i broke several bits... they weren't el' cheapo's either...
Unread 03-01-2010, 06:51 AM   #5
blacksmithdog
I drove a cone shaped burr on an air powered die grinder, up through the broken off bolts. I then drilled them to size. I through bolted them with nuts and lock washers on top. They are still tight. It's a royal PIA.
Whenever I take any bolt out anymore, I put some OMC water proof grease on the threads.
blacksmithdog is offline   Reply With Quote
Unread 03-01-2010, 07:12 AM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Jeep Horizons :: Fix Broken Upper Shock Bolts
TheBoogieman is offline   Reply With Quote
Unread 03-01-2010, 07:20 AM   #7
tjthorson
Dont drill them - get a large punch (12" long, round flat tip of at least 1/4"). Hold the punch verticle and use a 5 lb hand slegde to hammer "up" and bend the nuts out of the way. They are only tack welded along one edge. Once they bend up, you can reach in between the frame and tub (may have to loosen a few body bolts and jack up the body a bit if you dont have a body lift) and use pliers to bend back and forth until the nuts come out. Get 5/16" x 1" stainless steel bolts, 4 flat washers, and nylon locking nuts to put it back together and never worry about it again....
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! -> http://www.forgethannah.com
http://www.toddsplace.com
tjthorson is offline   Reply With Quote
Unread 03-01-2010, 07:34 AM   #8
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can also break the tack welded nut off the frame.
I think its a square nut if I remember correctly.
You can put a wrench on it and twist it right off. A breaker bar helps too.
Wheelin98TJ is offline   Reply With Quote
Unread 03-01-2010, 07:37 AM   #9
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
the bolts are hardened 10.9 steel...you need to Cobalt steel drill bits to get through them. drill a 1/16" pilot hole carefully with LOTS of lube. then follow it with a 1/4"....lots and lots of lube. long extended drill bits do wonders to help make the drill fit in the tight area.
if you have a body lift, you can stick a chisel in there on the weld-nut and attack the welds directly. have a buddy hit the chisel with a BFH/sledge. attack the weld itself...not the nut. you'll just dent the nut, you need to break the weld to bust the whole thing off.
Unlimited04 is offline   Reply With Quote
Unread 03-01-2010, 07:38 AM   #10
dualtjs
2011 JK Wrangler
Forgot about that method when I wrote the list. A big pair of vise grips works too.
Unread 03-05-2010, 07:10 AM   #11
greta
finally got this fixed with the help of my brother-in-law.
got three of the original four bolts back in their original position however had to drill a new a new hole slightly offset on the rear, upper, drivers side, closest to the center of the vehicle bolt b/c we could not get to that bolt because the gas tank was in the way... we would litterally had to have dropped the gas tank b/c of the angle it was at.
anyway, thanks for all the help and suggestions.
Unread 03-05-2010, 08:12 AM   #12
reckit21
Just did the same thing last weekend while installing my lift... We ended up going the hammer and chisel route... Never would have worked without the body lift though...
reckit21 is offline   Reply With Quote
Unread 01-13-2011, 09:08 AM   #13
Metzroth
"Get me a bigger hammer..."
Another vote for BFH and punch. I put off installing my rear shocks because I got under there and looked at them and knew they would snap. This morning I got on here before I started and saw that people had simply beat them out using a BFH so I went at each bolt knowing it was probably going to break. EVERY ONE broke. When I got done I took my 2lb sledge and a punch and beat them out. The first three came out in less than 5 minutes. I beat on the last one for about 45 minutes but it did come out. An hour later I am done with removing the broken bolts and simply need to head to the hardware store to pick up new bolts. Save your self the hassle and get the new bolts, nuts, and washers ahead of time. If you don't end up needing them, good for you! Atleast you will be prepared.
2000 XJ Classic - 33" GY Duratracs, 15x10 Cragar V5s, Crown HD springs, Clayton adjustable shackles, OME Nitrocharger Sport Long Travel Shocks, JKS Discos, extended brake lines, 2" poly spacers in front with V8 ZJ springs, Powerslot Rotors, Hawk HPS Pads, Hella E-Code headlight housings, Narva 100/130 Bulbs, Olympic Top Hat Rack, etc.
Metzroth is offline   Reply With Quote
Unread 01-13-2011, 01:45 PM   #14
greg_kulosa
greg_kulosa's Avatar
After snapping off both of the upper bolts doing the passenger side, I sprayed PB Blaster on the drivers side bolts every day for a week before I tried taking them out. Worked like a charm - they came right out without a problem.
Before I do my lift, I'm going to PB-Blaster everything under there to make sure I don't run into this problem.
greg_kulosa is offline   Reply With Quote
Unread 01-13-2011, 02:04 PM   #15
biffgnar
biffgnar's Avatar
Given that this thread is 9 months old, I'm hopeful that OP's problem is solved and he doesn't need any further advice. Additionally there are countless threads on this topic so even new people with this issue should have no problem finding answers if they use the search function.
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
biffgnar is offline   Reply With Quote
