Rear shocks are too long for the RC 2.5" spring lift. - Page 5 - JeepForum.com
post #61 of 370 Old 05-31-2009, 06:58 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by IrishRED View Post
Forgive my ignorance here but can this problem also be solved by increasing the length of the bumpstops by, say, 2.5 inches or is there more to it than that?
I understand that when you get a new kit you want it to be set up right so you are getting what you paid for and new proper length shocks would be ideal but would this work as an interm solution or not?
yes, you could put 2.5" bumpstops in. but you'll have hardly any up travel and you'll be hitting the bumpstops all day long driving on the street. thats why you want to fix the uptravel problem, so the axle can actually move up AND down. With the long shock RC setup its only moving down and hardly any up. And when it does move down, the shock isn't even being used fully because it extends more than the axle can move down.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #62 of 370 Old 05-31-2009, 07:37 AM
jenkins_1120
i just ordered that kit b/c of what i read on jf. just waiting to put it on when i go home on r&r. i guess i have to order my shockshifter bracket to go with it.
jenkins_1120 is offline
post #63 of 370 Old 05-31-2009, 07:44 AM
IrishRED
4-Banger Forever!
IrishRED's Avatar
Ok, but if I am running 33x10.5R15, won't I have to increase my bumpstops anyway, regardless of the "shock problem?"
IrishRED is offline
post #64 of 370 Old 05-31-2009, 10:17 AM
BWFBezerk
I'm running 33x12.5x15 and I have no problems with stock bumpstops. I have RC 2.5 + 1.25 bl and I have barely any rubbing at full flex, and I mean barely.
BWFBezerk is offline
post #65 of 370 Old 05-31-2009, 10:40 AM
IrishRED
4-Banger Forever!
IrishRED's Avatar
Right, but I only have the 2.5 lift - no body lift
IrishRED is offline
post #66 of 370 Old 05-31-2009, 10:41 AM
mudb8
want it rite or rite now?
mudb8's Avatar
bumptops don't need to be increased in the rear for 33" tire clearance, shock length is another story.... just the front for 33" tires, depending on the backspacing of the wheels, you may rub the flares, which only makes noise, not damage. 4.5" backspacing will clear the best.
if you're going with the rc 2.5 and the 1.25" bl you need a minimum of 1" bumpstops up front, the front shocks need 1" anyhow to keep em from bottoming out. without a bl, 2" bumpstops minimum up front...
the length of the rc rear shocks translates to 2.5" bumpstops even if you don't add in the axle mounted bumpstops. the shock relocation still needs about 1" of bumpstop...
I'm still waiting on pics of the brakets I made and installed last night, I wasn't the camera operator...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #67 of 370 Old 05-31-2009, 12:35 PM
mudb8
mudb8's Avatar
I'll send anyone thats interested in making their own, a pattern of my relocation brackets... they can be cut out with an angle grinder and welded into place, the materials needed are ...
1 scrap piece of 3/16" 2"x3" 12" long tube, cost is about 3 bucks at your local steel yard that has scrap cuttoffs.
2 5/8"x3" bolts
4 5/8" flat washers
2 5/8" lock washers
4 5/8" nuts
the hardware is around 7 bucks... you'll need a 5/8" drill bit to knock out the hole.
I'm only interested in helping with the solution to a common problem not bashing rc, (which isn't the ONLY 2.5-4" lift kit manufacture with this very same problem BTW) or making any money....
so, for all our fellow Do-It-Yourself people here....
a self addressed stamped envelope labled "shock mount" sent to po box 869 Estacada, OR 97023 will get you my pattern which isn't a copy of any you can buy, I free hand sketched, and fitted it using only a pencil and a 4 1/2" grinder...
pics will be here soon..
EDIT.. finally got the pics...
stock mount, rc 24" shock...
relocated mount, same rc 24" shock..
sorry for this one.. I did this after work.. it got dark.
this is it.. cut out using only a 4 1/2" cuttoff wheel in an angle grinder.. any DIY'er can do and benifit from this, including getting rid of the tail pipe rubbing the paint off the shock..
mudb8 is offline
post #68 of 370 Old 05-31-2009, 04:09 PM
BWFBezerk
I ran without my bl installed for about 3 months, no problems.
post #69 of 370 Old 06-01-2009, 10:06 AM Thread Starter
jgorm
jgorm's Avatar
why not just post it up here for everyone to see?
jgorm is offline
post #70 of 370 Old 06-01-2009, 10:40 AM
RecklessJ
Not wanting to sound ignorant but are the shocks too long for the 3.25 as well as the 2.5?
RecklessJ is offline
post #71 of 370 Old 06-01-2009, 12:30 PM
azcoyote
azcoyote's Avatar
You know, I noticed my shocks seemed to be a bit compressed too but I did not think to ask why...
I tested mine out and my LJs rears bottom out just coming off my drive way (az driveways have a bump, not smooth). It also explains some of the ride issues I have noticed on bumpy terrain... once they bottom out, all that energy is transmitted to rest of the jeep pretty harshly...
This happens on mine running a soft top and just me in the vehicle...
I am about to head out on a yearly camping trip to the mountains so I hope I do not have a failure when I load my gear... Would not be fun to be stuck out in the boons with a LJ full of gear and no rear shocks or blown mounts...
I still love the kit, the price, and the customer service from RC...
I think some shorter shocks will be needed in the rear though....
I will shoot some pics of mine tonight....
JEEPLESS... :(
azcoyote is offline
post #72 of 370 Old 06-01-2009, 01:34 PM
JESSETHELJ
JESSETHELJ's Avatar
Ive got the 3.25 lift I have nt had any issues. I wouldn't mind a shorter shock do to getting a little more travel. Here's some pics
I ended up welding up the rear trac bar bracket due to I was Shearing the bottom bolts off.
2004 LJ*RIP Love * Ex-Wife Stole you and Sold you *Current 1999 XJ Heep
JESSETHELJ is offline
post #73 of 370 Old 06-01-2009, 02:28 PM
RecklessJ
do you have a dropped pitman arm running the 3.25?
post #74 of 370 Old 06-01-2009, 03:30 PM
JESSETHELJ
JESSETHELJ's Avatar
Nope, I just did the front and rear adjustable track bars. But that was not required.
post #75 of 370 Old 06-01-2009, 07:56 PM
BWFBezerk
I have the 2.5 lift with 33x12.50x15's and stock bumpstops, this is what it looks like while resting with one wheel on and the other side on a jackstand, so pretty much how it sits normal. Does this look normal?
There seems to be about an inch of down travel left, I don't think that can be right?
Recs for simple 2" spring lift, without shocks or bumps DocJake JK Wrangler Technical Forum 3 10-10-2009 09:12 PM
rc 3.25" lift. spring spacers in the rear? G-MANtj TJ Wrangler Technical Forum 2 08-07-2009 11:52 AM
AEV rear spring relocator w/ RE 3.5" lift. MeltdWhiskey TJ Wrangler Technical Forum 0 06-24-2009 08:19 AM
Anyone with 3" FT lift with OME long travel shocks combo? OscarBlackTJ TJ Wrangler Technical Forum 4 01-28-2009 10:16 AM
Rear leaf spring conversion and RE 5.5" long arm kit (front) TOYJ-7 TJ Wrangler Technical Forum 5 01-21-2003 12:30 AM
