Rear shocks are too long for the RC 2.5" spring lift. - Page 16 - JeepForum.com
post #226 of 370 Old 06-19-2009, 12:23 PM
jim_bert
Originally Posted by bradthebard View Post
Well maybe you should just dedicate the next week or so to reading up on every, single, solitary post on this forum so you never have to ask a single question that has the remote possibility of having been asked or answered at some point in the past.
If there weren't so many posts telling people to do a search it would be easier to find the stuff you are looking for, ya know!
haha, you know what, you may be right, I guess I'll start reading now..
2001 Yellow Sport, I6, Dana 44 3.73 gears, 31x10.5 procomp AT on cragar soft 8s, silverstar headlights, black headlight bezels, raingler full netting system, raingler roll bar handles, EK motorsport maglite holder, Tuffy door lockers, Tuffy glovebox, stepshield door entry guards, 130w Halogen KC Daylighters on windhield mounts, kenwood kvt-819dvd, 5.25" front speaker conversion, door switch defeat, U-Pol Raptor liner, Dynomax Super Turbo Cat-Back Exhaust, Iggee seat covers, SAVVY LED Taillights.
jim_bert is offline
post #227 of 370 Old 06-19-2009, 04:42 PM
Yesfan70
Yesfan70's Avatar
Maybe Jeff needs to put the shock dimensions (both old and new) on RC's website. That would help with all the confusion, repetive posts, lack of searching, etc.
2004 Jeep WJ
Only in a Jeep
Yesfan70 is offline
post #228 of 370 Old 06-19-2009, 05:49 PM
jim_bert
That would be an excellent idea...
jim_bert is offline
post #229 of 370 Old 06-19-2009, 07:58 PM
MC_NickP
i just got mine done today. it took me 3 days, 12 total hours. some tips:
disconnect sway bars and track bars. front trackbar bolt was very tough to remove. i installed trrackbar bracket for the rear. when installing bracket, lower axle as low as possible because the gas tank gets in the way. then to put back in, use grunt force and jack to properly align axle. i drilled new hole for front trackbar. use 2 jack stands under frame and one jack to jack up axle. i extended both front and rear bumpstops by 2" and that gave me the perfect 1" hit before the shocks bottem out. i luckily had the correct shocks. remove bumpstops before attempting to remove springs. after frame is resting on jack stands, jack axle up, put in coil spring compressors, then lower axle slowly. this keeps the coil springs compressed, making it easier to remove. the front i had a difficult time with. i have a 1" puck up front. i had to use coil spring compressors, jack up other side of axle, push down axle as far as possible on my side, then use a prybar to get the spring back in. also big tip, learned for myself today, when putting in front coils, put the top over the bumpstop mounting location, and before the bottem of the spring is pushed in, put all bumpstop hardware inside the coil. it is very diffucult because of the new springs' design to fit anything bumpstop related into it after the bottem is in. when changing the shocks in the rear, use a nice long extension to access the rear upper shock bolts. thats all i can think of for now, but if more comes to me i will be sure to post. i will post some before and after shots aswell.
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
MC_NickP is offline
post #230 of 370 Old 06-19-2009, 09:05 PM
BWFBezerk
So pretty much the new shocks have the same problem, but in multiple pages of posts, RC has still not answered as to why the new shocks still have too long of a shock body?
BWFBezerk is offline
post #231 of 370 Old 06-19-2009, 09:28 PM
andrew383
since you guys like to measure stuff,can somebody that got the SS with there kit measure it for me?
97 tj-Locked up on 33's
andrew383 is offline
post #232 of 370 Old 06-19-2009, 11:29 PM
Yesfan70
Yesfan70's Avatar
LMAO!
2004 Jeep WJ
Only in a Jeep
Yesfan70 is offline
post #233 of 370 Old 06-20-2009, 06:36 AM
andrew383
LMAO!
seriously tho
post #234 of 370 Old 06-20-2009, 10:15 AM Thread Starter
jgorm
jgorm's Avatar
They have no acceptable answer. Either they say they didn't know and they are retarded, or they can say they didn't care.
Its the same size.
jgorm is offline
post #235 of 370 Old 06-20-2009, 12:21 PM
andrew383
what the lenght tho?i dont run a SS...
i have a different rear shock prob remember
post #236 of 370 Old 06-20-2009, 02:42 PM
BWFBezerk
my bad.....
post #237 of 370 Old 06-20-2009, 02:50 PM
mrgimble
2015 JK Wrangler
So then the stock shock would be better to use than the RC one because it has a shorter shock body, but same length when pulled out????? RC Seriously?
Wow, can I return my rear shocks and get some money back since they are useless and put in the kit just to get the price up, even though we're better off with stock shocks? RC, any answers to any of this?
That is a steering stabilizer not a shock.
mrgimble is offline
post #238 of 370 Old 06-20-2009, 03:43 PM
andrew383
none of that even makes since... read what i asked
post #239 of 370 Old 06-20-2009, 11:01 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Its the same size.
so.... what are the measurments of the new short shocks both extended and collapsed assuming the bumpers are cut off?
my understanding was the new was going to be about 23 and 13... wich would have at least 9.5" travel, the stock ones are around 8"...
that pic looks like a stock replacment...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #240 of 370 Old 06-20-2009, 11:15 PM
mudb8
mudb8's Avatar
what ss brackets are you refering to?
I think you're the one I said I'd send some actual brackets to since your current brackets are tipped up. is that right?
here's a new version I made today for more strength, more surface to weld insuring it won't get ripped off and will work with other shocks that aren't upside down..
this is a link the album, you can acually see how I made them without a write up...
http://s268.photobucket.com/albums/j...ck%20shifters/
mudb8 is offline
Recs for simple 2" spring lift, without shocks or bumps DocJake JK Wrangler Technical Forum 3 10-10-2009 10:12 PM
rc 3.25" lift. spring spacers in the rear? G-MANtj TJ Wrangler Technical Forum 2 08-07-2009 12:52 PM
AEV rear spring relocator w/ RE 3.5" lift. MeltdWhiskey TJ Wrangler Technical Forum 0 06-24-2009 09:19 AM
Anyone with 3" FT lift with OME long travel shocks combo? OscarBlackTJ TJ Wrangler Technical Forum 4 01-28-2009 11:16 AM
Rear leaf spring conversion and RE 5.5" long arm kit (front) TOYJ-7 TJ Wrangler Technical Forum 5 01-21-2003 01:30 AM
