Quantcast Rear shocks are too long for the RC 2.5" spring lift. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear shocks are too long for the RC 2.5" spring lift.
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 05-27-2009, 08:42 PM   #1
jgorm
I noticed some guys posting in the huge thread about the RC 2.2 rear shocks being too long. I just got my kit and I took a bunch of measurements and made a video of them in "action". They bottom out going off a curb, and there is about 2.5"(est) of space between the bumpstop and axle when they bottom out. My website takes a while to upload so i'll post a link to the pictures of the measurements once its up.
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/SPxNwpOrbL8&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SPxNwpOrbL8&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
jgorm is offline   Reply With Quote
Old 05-27-2009, 09:02 PM   #2
97casteeltj
something just doesn't look right
needing a new rig....
97casteeltj is offline   Reply With Quote
Old 05-27-2009, 09:03 PM   #3
97casteeltj
are you running the 2.2 shocks on stock suspension??
Old 05-27-2009, 09:05 PM   #4
mudb8
want it rite or rite now?
mudb8's Avatar
lol, I keep trying to tell em that, and thats was on the pavment, hitting up the grocery store. imagine what it does if you actually take it on a rough country road....
every one that thinks that rides better than stock or matches what OME does with their "correct length" shocks and proper rear bumpstops for a 2.5" lift, .... don't get off road....
24" shocks are fine up front, they don't belong on the rear...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 05-27-2009, 09:06 PM   #5
jforse
jforse's Avatar
Mine are they same way. Wondering why the uptravel was so short.
jforse is offline   Reply With Quote
Old 05-27-2009, 09:12 PM   #6
mudb8
mudb8's Avatar
the rear shocks are to long.. if you measure it for proper bumpstops, you'll find you need 2.5" bumpstops to keep the shock from bottoming out.
if RC would make a 22.5" shock or a shock with the main body length reduced by 2" and put it in the kit with the 24" fronts, they would have a well balanced system.. the 24" fronts with the 3.25" kit have about 4.5" of uptravel.. in reality, they are also to long without the extra 3/4" spacer.
Old 05-28-2009, 09:54 AM   #7
jgorm
Here is the axle at full droop (no sway bar connected)
No carpet, no seat/ seatbelts, softtop (same as with the video)
Here are more pics with the larger versions.
Old 05-28-2009, 10:05 AM   #8
Unlimited04
Unlimited04's Avatar
wow that travel sucks. glad i went with OME. RC is clearly trying to lower manufacturering costs by half assing things. they're using the 4" lift shock with a 2.5" lift, and putting a poly spacer on the shock piston to serve as a bumpstop. I see the point from a cost reduction standpoint, but it sure doesn't do their customers any good. That will surely destroy the shock mounts over time.
But, as the old saying goes, you get what you pay for
Unlimited04 is offline   Reply With Quote
Old 05-28-2009, 10:16 AM   #9
FloridaJeepGuy
If you take a hard drop, those shocks are going to get damaged. Shocks aren't designed to take that kind of punishment. Thats what the bumpstops on the frame are for. Crappy situation!
(Sold) 1983 Blue CJ-7
(Sold) 1995 White YJ Rio Grande
(Sold) 2003 Wrangler X 4.0 5sp 31X10's
(Presently) 2003 BMW M3 Coupe
FloridaJeepGuy is offline   Reply With Quote
Old 05-28-2009, 10:44 AM   #10
JUPITERSAHARA
2010 JK Wrangler
I think R/C has two different length shocks; one for the 2.5" lift and one for the 4" lift. I have the same shocks as you and have taken them for some mild offroad action with no problems at all. Maybe Jeff from R/C can chime in and answer some questions...
2010 JK Wrangler 2-door Sport
Deep Water Blue
Hardtop
4 speed Automatic
Stock....for now!!!
JUPITERSAHARA is offline   Reply With Quote
Old 05-28-2009, 10:51 AM   #11
LTDan
Has anybody talked with RC to see if they're willing to make changes to the kit and help a bruther out? I have the kit too, and you could have made those pict's under my jeep.
Low Output 4 Cylinder Jeep Club #2001
Mine: 2001 TJ 2.5L, 5spd, Silver Stone
Hers: 2004 WJ 4.0L, Bright Silver
LTDan is offline   Reply With Quote
Old 05-28-2009, 10:51 AM   #12
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its not the easiest solution, but you could cut the lower shock mounts off the axle and weld them on the backside of the lower control arm mounts.
This will give you the room you need for uptravel.
It will also improve the ride slightly and will clean up the brackets hanging down below the axle tubes.
98 TJ
Wheelin98TJ is online now   Reply With Quote
Old 05-28-2009, 10:55 AM   #13
jgorm
I bottomed them out going off a freakin curb!
Wouldn't I have to fab up some upper mount if i did that? I have already thought about doing that with some 1/4" steel. I saw a mount done from Stu/Blaine that looked killer, and figured i could make a mount with a couple extra holes for when i upgrade to a 4" lift in the future.
Old 05-28-2009, 11:10 AM   #14
Wheelin98TJ
JEEP FREAK
You wouldn't have to change the upper mount, but the mod you are referring to is very nice.
I have my lower shock mounts on my axle set up like I described and it works well.
The shock can is close to the frame, but it clears with enough room.
98 TJ
Old 05-28-2009, 11:24 AM   #15
jgorm
Got any pics? (add another project to my long list!!!)
Glock Forum
