Rear shock shifter - JeepForum.com
post #1 of 12 Old 05-09-2009, 11:48 AM Thread Starter
Gabe
Gabe's Avatar
Rear shock shifter
What's available as far as a lower bracket that will relocate the shock?
I want to move it further up and towards the tire in order to avoid snagging it on a rock.
This should also help get a bit more downtravel out of the shock, maybe 1 or 2 inches, huh?
What have you guys used and how well does it work?
Originally Posted by Rubi22
Holy ****, did someone log onto Mean Fish's account and say something thoughtful?
Gabe is offline
post #2 of 12 Old 05-09-2009, 12:43 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There is no free ride. If you move the bottom up, it will likely bottom the shock out on uptravel.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 12 Old 05-09-2009, 01:06 PM
emev0l
AEV makes this:
https://secure.aev-conversions.com/s...ode=NTH23100AC
Click on the instructions at the bottom of that page for installed pictures.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #4 of 12 Old 05-09-2009, 01:22 PM Thread Starter
Gabe
Gabe's Avatar
I've done some measurements on the ramp and my bumpstops still have 1 inch before they touch. My shocks have about 1.5 inches before bottoming out.
Gabe is offline
post #5 of 12 Old 05-09-2009, 01:27 PM
sitdwnandhngon
1987 YJ Wrangler
Take some square tubing and make your own, very quick and easy, just weld them where you want them. You can see how this one was done.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline
post #6 of 12 Old 05-09-2009, 01:35 PM Thread Starter
Gabe
Gabe's Avatar
I hate these RE shocks. the ride is awseome, but there's no way they're made long enough for the 3.5 kit. Not enough downtravel whatsoever.
I got the 2"-3.5" monotube shock kit and they just aren't long enough. Front or rear. Switching over to Bilsteins for a 4" kit. They're 2.5-3 inches longer extended than the RE shock kit.
Gabe is offline
post #7 of 12 Old 05-09-2009, 02:14 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Unless you used two ramps, your measurements are invalid.
I am Savvy
mrblaine is offline
post #8 of 12 Old 05-09-2009, 02:23 PM Thread Starter
Gabe
Gabe's Avatar
You mean cross flexing the axles to their opposite extremes?
Gabe is offline
post #9 of 12 Old 05-09-2009, 02:28 PM Thread Starter
Gabe
Gabe's Avatar
Blaine, OT question, you have the 3spd auto that came in most TJs right? What, if anything, have you done to help its performance or durability? Has it ever been rebuilt, and if so, at what mileage?
Gabe is offline
post #10 of 12 Old 05-09-2009, 02:34 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yep, no matter how much you cycle, forklift, or ramp your suspension, it always reacts differently offroad and most times much further than you ever suspected.
I am Savvy
mrblaine is offline
post #11 of 12 Old 05-09-2009, 02:38 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I run the deep pan, but that's before I figured out that even a deep pan will run out of fluid at extreme angles if the trans is even slightly under full.
Other than that, nothing.
Mine was rebuilt at 30,000 because I shoved the flat skid up into the pan, collapsed it, and restricted the filter on the pick up. No fluid smokes things quite fast.
The other is kicking along solidly at 60K plus on the odo.
I am Savvy
mrblaine is offline
post #12 of 12 Old 05-09-2009, 10:11 PM
mudb8
want it rite or rite now?
mudb8's Avatar
the aev/nth shock shifter is easy to install and adjust,
when setting bumpstops I do it on level groud without flexing it... slow speed articuating isn't likely to damage the shocks and mounts as hitting a bump that bottoms out both shocks at the same time does... and jumping.
this is how I do it..
measure shock travel at ride height...
I set the stops to contact 1" before the shock bottoms out, the bumpstop will compress till it's flat.
like mrblaine said.. stopping for articulation is a little difficult... these are front pics obviously, tho the rear adjusts the same and also lands the axle pad in an odd manner..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
AEV Shock Shifter Kit, info needed. MayRoll TJ Wrangler Technical Forum 2 04-30-2009 01:02 AM
Nth Shock Shifter and OME Shock bushing issue. tcmault TJ Wrangler Technical Forum 3 04-16-2007 07:49 PM
rear shock problem (shock hits coil cup) gundy33 TJ Wrangler Technical Forum 17 04-12-2006 02:59 PM
Engine/shifter/rear view viberation, normal? jzmtl TJ Wrangler Technical Forum 9 02-21-2006 11:32 PM
broke rear upper rear shock mount bolts Blackjackbender TJ Wrangler Technical Forum 7 07-23-2005 12:47 AM
