#1 | |
Rear Shock Relocation Brackets
My rear shocks have been dented by the plate that seats the rear springs. I think that inverting the shocks might solve the clearance problem, but that was not an option with the shocks that came with the kit I installed. I have seen rear shock relocation brackets in 4WD Hardware catalogs and wonder if this what I need. Does anyone have some pics of what these look like installed? Will this be the answer to my problem?
2004 TJ Wrangler Rubicon - 5.25" Total Lift, Antirock, Various Skids, Winch, 35" MT tires, Roof Rack. Matching Off-Road Teardrop Trailer. 1993 XJ Cherokee - 3" Lift, 31" tires Previous Jeeps - 1981 CJ-5, 1985 CJ-7 |
#2 |
Yes, they will solve your problem. Try these from JKS:
Visit My Homepage! |
#3 | |
Web Wheelin'
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out 96 Jeep XJ Sport, parted out and scrapped Tummy Tuck without a body lift. Finished!! |
#4 |
Thanks for the replies to my post. These look like they will move the shock back enough to prevent contact with the spring perch at articulation.
#5 |
to solve that on my jeep i bought DT3000 shocks, they can be mounted upside down....nothing touches now
*i needed shocks anyway...
http://www.kifourwheelers.com/ |
#6 |
These work well for my setup...
#7 |
those bolt on shock extensions will work with moderate wheeling conditions. Mine had to be welded on bc they kept getting loose and cracked.
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more... |
#8 | |
want it rite or rite now?
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#9 |
um... the bolt on piece can be as strong as you want but with that angle it puts a lot more stress on the stock bracketry, and yours look homemade 1/4 inch steel?
#10 | |
#11 |
It could be answer to your problem, and they could cause a whole different set of problems. I don't know if you wheel hard in the rocks, or wheel the mall parking lot hard. But those brackets would just rip off on me before lunchtime where I wheel.
These aren't great pics, but it's what I could dig up for now. I'd recommend you move the bottom mounts outboard. Doing this does a few things. It reinforces your lower control arm mount, it moves the shock near the tire so it will hit objects about 95% less, and it gives the shock a better angle to work with. It also takes care of the problem hitting the spring perch and it gives more room at the gas tank too. And for comparisons sake:
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion." |
#12 | |
Mine are slowly being eaten away- I have a set of Ford shock mounts ready to be welded on the top outboard side but I haven't gotten to it yet.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times. |
#13 |
No, they don't hit the frame. It's very close, but I have more droop than compression. When the axle droops the shock is just about straight up and down. I'll try to find a pic. Of course the full outboard set up is best, but I didn't want to get in to that, and seeing as the OP is talking about the relocation brackets that just move them rearward I didn't go in to that.
#14 |
Best I can do right now. Kind of hidden by the tree but you get the idea.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
