Rear shock mount broke.....????? - JeepForum.com
post #1 of 3 Old 10-02-2008, 07:39 PM Thread Starter
hershseany
I have a 2001 Jeep wrangler with a 2inch lift. Yesterday my right rear shock came loose and was hitting my exhaust. I took off the shock and noticed that the top part of the mount had broken off and I also lost the top bolt connected to the shock. Does anyone know where I can get the parts to fix it myself? And is it dangerous to be driving around with a shock missing??
hershseany is offline
post #2 of 3 Old 10-02-2008, 07:50 PM
BlackBellamy
BlackBellamy's Avatar
If the part that broke is the bar pin (the part with the U cut on each end that goes through the top shock bushing), then you'll need to replace the shock because the bar pin comes with the shock. And you'll need to get two shocks because you should never just replace one shock. The bolt you can get from any real hardware store. While you're at it, replace both and make sure they're either grade 5 or 8.
Driving with a shock missing is doable, but you should be careful. Your rear will bounce a lot more and you'll need to watch yourself real carefully on turns.
Also, and this might be why your bar pin broke in the first place, you need to make sure your shocks are the right length for your lift and you have sufficient bumpstops to prevent the shock from being overcompressed - otherwise you'll just break your bar pin again when you compress your rear.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #3 of 3 Old 10-02-2008, 09:30 PM
rubidriver
check out my thread on this subject, the exact thing happend to me, it was even on the same side as yours hitting the exhaust.
http://www.jeepforum.com/forum/f9/shock-bolt-broke-599612/
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
Rear upper shock mount broke 2003X TJ Wrangler Technical Forum 24 11-20-2009 05:45 PM
Rear, upper shock mount on frame broke. Black87 YJ Wrangler Technical Forum 7 06-06-2009 12:11 PM
Broke rear shock mount GRN_BEAST95 YJ Wrangler Technical Forum 13 02-10-2009 10:26 PM
Just broke my rear shock mount djennis20 YJ Wrangler Technical Forum 14 01-10-2007 10:27 PM
broke rear upper rear shock mount bolts Blackjackbender TJ Wrangler Technical Forum 7 07-22-2005 11:47 PM
