Rear shock is loose on bottom 'bolt' - JeepForum.com
post #1 of 6 Old 04-26-2011, 10:53 PM Thread Starter
Maverickxeo
Its a pro comp shock (pretty sure) with a 4" long arm lift. I noticed today I heard quite a bit of thunking and squeaking coming from the back right tire. I got out, and shook the Jeep, and noticed that the shock was moving slightly on the bottom bolt (the one that mounts to the axle). I checked the bolt, and it was tight; but Im assuming the bushing is toast on the shock.
I was looking to replace the shocks anyways, but how bad is this to leave for a while?
Maverickxeo is offline
post #2 of 6 Old 04-26-2011, 10:55 PM
hustler905
How long is a while? Bushings are pretty cheap.
hustler905 is offline
post #3 of 6 Old 04-26-2011, 10:57 PM Thread Starter
Maverickxeo
Well that depends haha. Id like to buy a new set of shocks so I dont want to do the work twice but funds are low.
Call it lazy; I call it efficient.
post #4 of 6 Old 04-27-2011, 12:43 AM
oakmckinley
The damage you'd do is if the bolt gave way from it wearing on it. Who knows what that swinging shock will hit once it comes loose? gas tank etc.
I agree with the above post that bushings are cheap, and the bottom bolts are the easiest IMO. Just change it.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #5 of 6 Old 04-27-2011, 02:27 AM Thread Starter
Maverickxeo
Okay; so just curious; what is it called; and who should I get it from? Do I need to get one from the shock manufacturer, or is it a part that the dealership/partstore can order?
post #6 of 6 Old 04-27-2011, 05:00 AM
trotter8
I just had the same thing happen to my Skyjacker shock. The dealer just sells the whole shock (at least that is what they told me). I ended up going through Skyjacker to get the bushing part number and then ordered it through one of their distributors.
97 TJ 4.0L, Auto, 2.5" Lift, 1.25 BL, 1" MML, F&R Tube Fenders, 35" BFG AT, 4.56 HPD30/8.8
trotter8 is offline
Bolt on the bottom came loose. Chillyman TJ Wrangler Technical Forum 3 04-18-2011 11:46 AM
Rear pinion yoke bolt came loose. Isaiah17 YJ Wrangler Technical Forum 3 11-06-2008 10:20 AM
rear passenger shock keeps breaking loose. PatriotCrawler TJ Wrangler Technical Forum 6 02-13-2008 08:57 AM
rear track bar bolt loose, cant get tight????? BeerMonkeY TJ Wrangler Technical Forum 7 11-13-2005 10:20 AM
Bottom shock bolt is loose DrunkPenguin YJ Wrangler Technical Forum 15 09-29-2005 08:33 AM
