Rear Seatbelt wound up and wont release - JeepForum.com
post #1 of 9 Old 10-11-2008, 02:48 PM Thread Starter
conifers4
I'm re-installing the rear seat belts after "herc"ing the tub and I came across a huge problem. I allowed the rear seat belt mechanism to wind up the entire seat belt minus maybe 6 inches or so. Now the belt is locked in the spool like they do when you jam on the brakes. There has to be a way to release the tension therefore releasing the belt....right?? I'm stumped ? Keep in mind neither end is bolted in, both ends are dangling by the sport bar. Am I missing a button or something? Any help extremely appreciated!!
AMERICA IS FULL
conifers4 is offline
post #2 of 9 Old 10-11-2008, 02:54 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
take the cover off, (dont worry spring are contained) you will see locking pin, release it and open the belt
RnEmOvr is offline
post #3 of 9 Old 10-11-2008, 03:35 PM Thread Starter
conifers4
ok gonna run outside and try that
AMERICA IS FULL
post #4 of 9 Old 10-11-2008, 03:39 PM Thread Starter
conifers4
the plastic decorative cover is riveted to the belt housing, I'm gonna have to drill the rivet out I guess
AMERICA IS FULL
post #5 of 9 Old 10-11-2008, 03:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Our seatbelt mechanisms will not release unless held perfectly vertical, in the same position as they are mounted in. If they are tilted at all, the little ball in the bottom of the mechanism will roll out and lock it up.
Jerry Bransford is offline
post #6 of 9 Old 10-11-2008, 03:47 PM Thread Starter
conifers4
Jerry, once it's locked up can it be unlocked? I mean, if I go hold it just right it'll unlock or Did I now wind it past the point of no return
AMERICA IS FULL
post #7 of 9 Old 10-11-2008, 03:48 PM
jgtree
i had this problem when i took mine out to paint the cover.just take your time with it.don't drill or get frustrated.just do like jerry said,it will come back out.
So, is there any tread left on the tires? Or at this point would it be like throwing a hot dog down a hallway?
jgtree is offline
post #8 of 9 Old 10-11-2008, 03:51 PM
Jerry Bransford
Administrator
Just go hold it perfectly vertical and still so the ball won't roll out of position and wiggle the belt in/out. It'll eventually unlock and retract.
post #9 of 9 Old 10-11-2008, 03:57 PM Thread Starter
conifers4
Once again the fine folks at jeepforum save me time and frustration. I did exactly what you told me to do and it worked on the first try. Thanks for a job well done.
AMERICA IS FULL
3rd seatbelt for rear of 2dr? Cavi JK Wrangler Technical Forum 2 08-16-2009 03:24 PM
Driver Side Seat Belt Wont Release robmerefj YJ Wrangler Technical Forum 7 11-14-2008 07:28 PM
Put in new clutch...now it wont release. drumsaregood46 YJ Wrangler Technical Forum 5 10-27-2008 10:14 AM
seat belt wont release ex-toyota YJ Wrangler Technical Forum 10 04-07-2005 01:29 PM
took off rear seatbelt now it wont unretract JeepZJlover TJ Wrangler Technical Forum 3 04-05-2005 10:06 PM
