Rear seat with headrests - JeepForum.com
post #1 of 10 Old 02-24-2013, 05:25 PM Thread Starter
jamborick
My kids are coming out of cars seats and I'd feel better with headrests in the back seat. The only one I can find us Bestop Trailmax II. Anyone know of another option. I don't usually like choosing the best from a field of 1
jamborick is offline
post #2 of 10 Old 02-24-2013, 06:03 PM
ImaginaryFriend
ImaginaryFriend's Avatar
If you want a new seat, I don't have anything to add. But consider this low cost, easy solution...
Go to the junkyard and find some headrests in the size and color you like. Drill holes in the seat frame, install. I used an old soldering iron to burn holes in the seat foam and through the fabric, it made perfect holes. You can secure the headrest posts multiple ways, but I left mine so I could slide them on/off. I've seen others put an extra crossmember on the seat frame so the headrest posts slide through the frame and new crossmember, but I don't believe it's necessary. I've seen many different makes/models seats disassembled and the factory seats with adjustable headrests are built the same way. Holes or small tubes welded to the top of the seat frame...no extra bracing.
ImaginaryFriend is offline
post #3 of 10 Old 02-25-2013, 01:55 PM Thread Starter
jamborick
Excellent idea! Thanks a lot
post #4 of 10 Old 02-27-2013, 04:31 PM
estebanshadow1
Asi es como quedó mi asiento trasero, pertenecen a una chrysler voyager, el color es identico al interior de mi jeep.
estebanshadow1 is offline
post #5 of 10 Old 03-01-2013, 09:57 PM
joe108
That is a great idea!
joe108 is offline
post #6 of 10 Old 03-02-2013, 08:34 AM
PDoyle
PDoyle's Avatar
There was a thread posted a couple years ago on this install. The guy used head rests from a Hummer. The looked great. I've had an Ebay search for a while on Hummer headrests. I've seen them go for as low as $40. a set FYI.
BTW, great install OP.
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar.
SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage.
PDoyle is offline
post #7 of 10 Old 03-02-2013, 12:18 PM
miketrock
If you got in a bad wreck, could those black steel posts impale somebody if things got bent? Looks like there should be a second cross support down lower so they stay confined and straight in a wreck. Otherwise, yeah, pretty cool idea.
miketrock is offline
post #8 of 10 Old 03-02-2013, 12:24 PM
Benderff
Benderff's Avatar
If the wreck is bad enough to bend the seat to the point the ends of the head-rest could impale someome, I would think you have much much worse problems.
I do like over-kill, so adding a support bar is a cool idea.
Benderff is offline
post #9 of 10 Old 03-02-2013, 05:51 PM
Sahara0643
You can get the Corbeau rear bench with headrests.
Chris
Chris
2005 Sahara LJ
Currie Arms, 2" BB, Tummy Tuck
AtoZ Cage, Trxus MT 285/75 on MOABs
Sahara0643 is offline
post #10 of 10 Old 03-02-2013, 08:14 PM
Hesher420
http://www.jeepforum.com/forum/f9/po...l#post14079654
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
