Rear Pinion - Currie CA's Lowers - Page 2 - JeepForum.com
post #16 of 25 Old 10-19-2010, 06:03 PM Thread Starter
UncleWilson
UncleWilson's Avatar
i'm selling a nice 1" t-case drop kit:
http://www.jeepforum.com/forum/f126/...06-tj-1116030/
I saw that earlier today, saw it was in denver but never looked at name. Do you have a guess on how much shipping for it would be?
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #17 of 25 Old 10-19-2010, 06:32 PM
F9K9
I'm running The Currie SAs, AEV/Nth TT and a M.O.R.E. MML on an '03 Rubi with 35s and I am not having any issues. Would a MML help you guys any? I dunno, am just tossing it out for thought.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #18 of 25 Old 10-19-2010, 08:27 PM Thread Starter
UncleWilson
I have mml/bl, lopro transfer mount, 1" deep skid, and 4" currie lift. Putting my driveshaft at about 25 degree. I was told 15-18 is the safe max
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #19 of 25 Old 10-19-2010, 08:37 PM
emev0l
What city are you in, I should be able to come out and take a look if your close. I know I have a transfer case drop I never used that I'll just give you.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #20 of 25 Old 10-20-2010, 06:46 AM Thread Starter
UncleWilson
Sounds good, Sent you a PM
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #21 of 25 Old 11-03-2010, 01:36 PM
emev0l
Did you get everything straightened out?
emev0l is offline
post #22 of 25 Old 11-04-2010, 10:31 AM Thread Starter
UncleWilson
I did get it up and running again. Pinion for rear is set at 19. I ended up dropping the slid about 1.25" shortening rear uppers and lower and bending the GTS out of the way. If I go for an aftermarket GTS savvy or rokmen I'll be able to push the axle farther rearward by about an inch.
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #23 of 25 Old 11-04-2010, 12:46 PM
emev0l
If your looking for some mud to test everything out a bunch of people are going to Rizzo's Bog, Rizzo's Bog
A lot of people go to The Mounds on Thanksgiving day, The Mounds ORV Area
emev0l is offline
post #24 of 25 Old 11-04-2010, 12:47 PM
vosevichs
I extended my lowers 1/2" and my tires (35's) were hitting the rear of the wheel wells when compressed
Scott Vosevich
vosevichs is online now
post #25 of 25 Old 11-04-2010, 12:55 PM
Dogman
Dogman's Avatar
Originally Posted by Dr_Jim View Post
Interesting info.
This still does concern me though. There surely is a basic/standard solution to a 4" lift + TT on 35's.....sounds like an incredibly common setup. Figured it would be boilerplate by now......
I would be interested in knowing the measurement from the ground to the TC output shaft. And maybe the angle of the output shaft. Not all belly-up skids are going to have the same TC height and angle (my 1" skid compared to brand X 1" skid). I will also be using Currie 4" springs, so this talk of extreme angles concerns me.
John 3:17
Dogman is offline
control arm , control arm bolt , currie , lower control arms , pinion angle
Currie High Pinion MattTheMudder TJ Wrangler Technical Forum 35 05-04-2010 11:06 PM
currie high pinion ? kasbiker38 YJ Wrangler Technical Forum 7 02-05-2009 11:14 AM
Upper Rear Ca's airframer TJ Wrangler Technical Forum 1 03-03-2008 07:39 AM
Best way to loosen RE upper rear CA's?? blacktjsport TJ Wrangler Technical Forum 3 05-29-2007 10:46 PM
Daystar Adj Upper Rear CA's RubiconSS TJ Wrangler Technical Forum 13 09-03-2005 08:30 PM
