Rear Main Seal Replacement - JeepForum.com
post #1 of 9 Old 03-15-2006, 12:35 PM Thread Starter
PolloLoco
need more lemon pledge
PolloLoco's Avatar
So I hear that the rear main seal is something that often times needs to be replaced. I plan on replacing my rusting oil pain this summer, should I take the extra steps and preemptively replace the rear main seal?
PolloLoco is offline
post #2 of 9 Old 03-15-2006, 12:46 PM
BChamberlin
BChamberlin's Avatar
I'm in the same boat... gotta replace my main seal (at least I think it's the main seal). I've got a itty bitty spot under the center, actually dripping from the v shapped metal on the transmission case. I'm assume this is the main seal. Not really sure how to check without getting under there pulling stuff off.
BChamberlin is offline
post #3 of 9 Old 03-15-2006, 12:59 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
Check this out.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #4 of 9 Old 03-28-2006, 08:06 AM
BChamberlin
I just checked out the link as my leak is getting pretty bad. I'm can sometimes be "kinda" mechanical.... and I'm wondering if I should try this. I hate doing things that leave me totally screwed if I mess them up.
2008 Wrangler X
post #5 of 9 Old 03-28-2006, 03:49 PM
jeepsterguy
2011 WK
Could it be a valve cover? Oil adapter? Head?
Many things can leak, changing the wrong part won't fix your leak.
How about cleaning the engine nice and dry, including the back and then watching for the leak. If the usual suspects stay dry, what is left is the rear seal.
jeepsterguy is offline
post #6 of 9 Old 03-28-2006, 04:55 PM
brossie
Rear main seal is very easy to change out.
brossie is offline
post #7 of 9 Old 03-28-2006, 05:44 PM
jeepsterguy
2011 WK
In that case go ahead and change it even if there is nothing wrong with it.
IMHO just the fact that you'll have to clean the oil pan is enough to keep me away till it leaks.
post #8 of 9 Old 03-28-2006, 05:55 PM
munzaruby
I have an 05 with 6,00 miles that has a bad rear main leak
munzaruby is offline
post #9 of 9 Old 03-28-2006, 07:12 PM
bobjp
If you are going to be taking off the oil pan anyway, then you may as well do the rear main seal. It isn't much more work after taking the pan off.
97 TJ sport.
bobjp is offline
2.5 rear main seal Replacement Gonewhln YJ Wrangler Technical Forum 4 04-14-2009 12:27 PM
92 yj rear main seal replacement Q BRAX YJ Wrangler Technical Forum 7 10-10-2007 07:29 PM
?'s about rear main oil seal replacement bob082484 YJ Wrangler Technical Forum 12 04-30-2007 11:15 AM
rear main seal replacement 87 alienball YJ Wrangler Technical Forum 0 06-01-2006 11:17 AM
Rear main seal replacement TellyDSP YJ Wrangler Technical Forum 9 04-25-2005 09:24 PM
