Rear leaf spring conversion and RE 5.5" long arm kit (front) - JeepForum.com
post #1 of 6 Old 01-20-2003, 11:00 PM Thread Starter
TOYJ-7
I just put leaf springs on the rear of my TJ and it rides 100 times better, then rear coils(I had RE 4.5" coils). All the lifted problems that the TJ's have are GONE! I used a 99 toyota taco rear axle with E-locker, 5" all pro toyota leafs(front toyota leafs), M.O.R.E shackles, and used all pro hangers. I also did RE 5.5" long arm kit coils in the front. I am sitting at about 96" wheel base and was at 92". With the long arm and the rear leafs it rides great and would do it again. As of right now I don't have the e-brake hooked up, E-locker, or the adapter for the spare.
TOYJ-7 is offline
post #2 of 6 Old 01-20-2003, 11:25 PM
dejablu311
dejablu311's Avatar
Looks great man. Did you do an SOA conversion? Is the road ride better?
dejablu311 is offline
post #3 of 6 Old 01-20-2003, 11:25 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
(( K9 In his best John Belushi voice ))
. . . I LIKE IT!!
I can't quite see it, is it SOA? Any issues with spring wrap? More pics!!
K9Jeep
K9JEEP is offline
post #4 of 6 Old 01-20-2003, 11:42 PM Thread Starter
TOYJ-7
Yup it's SOA and it rides great do to the soft and I mean soft leaf springs. Where seems to be very little wraping
TOYJ-7 is offline
post #5 of 6 Old 01-20-2003, 11:55 PM
dejablu311
dejablu311's Avatar
Are you going to change the front bolt pattern to match the rear? I would like to know how you installed the e-locker switch too. More pics would be sweet too.
post #6 of 6 Old 01-21-2003, 12:30 AM Thread Starter
TOYJ-7
I am using an adapater until I change the front end out. I don't have the E-locker hooked up yet.
TOYJ-7 is offline
Rear shocks are too long for the RC 2.5" spring lift. jgorm TJ Wrangler Technical Forum 369 03-08-2012 07:44 PM
TJ rear leaf conversion Bachman TJ Wrangler Technical Forum 31 03-15-2010 08:23 AM
YJ: Coils Spring Up Front and Leaf Springs in the Rear? ValleyJeeper YJ Wrangler Technical Forum 8 02-17-2010 07:56 AM
YJ front spring plat to rear shock conversion YJames90 YJ Wrangler Technical Forum 9 09-05-2008 04:52 PM
Hanging the rear spring shackle from another leaf spring, NOT the frame. ideas? Big-n-Broke-YJ YJ Wrangler Technical Forum 42 09-03-2007 08:32 PM
