Rear fold and tumble seat release cable broke, can anyone help? - JeepForum.com
post #1 of 8 Old 11-14-2010, 12:04 PM Thread Starter
ericpeck
When i pull the handle to fold my rear seat forward only the pass side releases. The cable that goes to the drivers side latch has come loose where the pivot point is on that side, ive looked and cant find exactly where it has come loose. Does anyone have some pictures or a diagram that would help me?
ericpeck is offline
post #2 of 8 Old 11-14-2010, 02:23 PM Thread Starter
ericpeck
I got it figured out and didnt even break anything else in the process. Ill post some pictures for future reference
ericpeck is offline
post #3 of 8 Old 11-15-2010, 07:54 PM
bds5
What did you have to do, Im ready to break something. My rear seat driver side cable is broke also.
bds5 is offline
post #4 of 8 Old 11-15-2010, 08:01 PM
bsexton
Newbie
bsexton is offline
post #5 of 8 Old 11-16-2010, 03:20 AM
vector6
Originally Posted by bsexton View Post
wrong application, they are having trouble with the 03-06 REAR seat.
vector6 is offline
post #6 of 8 Old 12-29-2010, 11:29 AM
andy42s
How'd you fix it? Mine is doing the same thing, and I can't get any help!
andy42s is offline
post #7 of 8 Old 06-16-2012, 07:41 PM
HammerSC
This also happened to my 05. I called the dealership and the only way you can get the cable is to buy the latch with cables $113.00. I thought I would let you know how I was able to fix it. If you reach under the seat back you can take the seat cover loose and slide it up a few inches. If you move the latch you can see the part working on the good side, you can move the broken one with a flat head screwdriver. I took the seat out and removed the old cable. Pull the end off of the cable that was at the top. I grabbed a cable for a bicycle and pulled the cable out of the cover. I slid the cable back in the cable cover from the seat and put the end back on it. Once you put the cable back in you will need to put a cable clamp on the top of the cable to fasten it to the handle. I found one that i could tighten a screw up on the cable so it could be adjusted. Feed the cable through the handle. With the handle down, pull the cable far enough to release the latch and, tighten the clamp. When I let go of the cable it worked perfect. I'm not much of a writer but, I couldn't find any info on this and, I thought it might help someone else.
HammerSC is offline
post #8 of 8 Old 09-15-2015, 07:55 AM
Bullethead
This final part is where I am stuck. I have the repair kit from Walmart. I have 1 end of the new cable in the mechanism (down by the corner of the bottom of the seat), I have no idea however how I am going to tighten it up against the handle release. Have you any photos of what you used or your set up? Its hard for me to picture what you are describing.
Bullethead is offline
Passenger Fold and Tumble cable broke herxjhistj TJ Wrangler Technical Forum 4 08-24-2009 09:06 AM
Fold and Tumble Rear Seat Douglas S. YJ Wrangler Technical Forum 5 11-23-2007 08:18 PM
Rear seat (fold and tumble) question ZonaWrangler YJ Wrangler Technical Forum 2 06-14-2005 08:54 PM
Fold and tumble rear seat questions gilldawg79 TJ Wrangler Technical Forum 14 05-19-2005 09:42 AM
Fold and Tumble rear seat Yoink YJ Wrangler Technical Forum 7 11-23-2004 03:37 PM
