Rear extended Sway Bar links... - JeepForum.com
post #1 of 8 Old 04-18-2007, 07:55 PM Thread Starter
CHRRRIS
CHRRRIS's Avatar
So I got this lift that is just missing these rear-extended sway bar links, and I have looked around, and the best I could find (That will work with 3" SL) is this Skyjacker pair from Quadratec:
http://www.quadratec.com/products/26028_002.htm
It seems like it comes with alot of stuff, and works with my 3" kit...
I've also seen Quadratec's Rubicon Express, (I think) extended REAR sway bar links, and they are very cheap (like $30) but it doesn't say for how much lift they will work with..
Anyboyd know any good rear sway bar links for a 3" lift...and I can't get disco's because I am on a budget after buying the lift and tires... just looking for solid links that are good and inexpensive.
Also, the kit comes new with a Drop Pitman arm, but the guy said that the shop that installed the kit never put it on because he didn't need it... Does anyone think I will need one for the 3" SL?
Edit: Lastly, should I look into a new steering stabilizer as well? I've heard a lfit and 33's will start to worsen the steering...
My TJ is a '97-2.5-Auto by the way...
It's easier to go down a hill than up it but the view is much better at the top.
-Henry Ward Beecher
Current - '98 Black Z28 with some goodies
Previous - '97 Gun Metal Blue TJ
Northern Illinois Extreme Jeep Club
CHRRRIS is offline
post #2 of 8 Old 04-18-2007, 10:31 PM
SecondTJ
SecondTJ's Avatar
No need for rear disconnects, stick with solid links. The only place i could find them was from BDS for $80, i ended up picking up some used ones for much cheaper.
You don't need the drop pitman arm, so don't worry about it.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 8 Old 04-18-2007, 11:25 PM
PackMan
PackMan's Avatar
Location: Home of the Super Bowl XLI Champion Indianapolis Colts
I've heard that below 4" of lift (or even more), you don't need new sway bar links for the rear. Your angles are still within a functional range.
PackMan is offline
post #4 of 8 Old 04-18-2007, 11:33 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Leave the dropped Pitman arm in the box, the installer had the smarts to know your TJ didn't need it. If he had installed it, your TJ would have bump steer now.
And even if you could find them, don't install quick disconnects for the rear antiswaybar, if that's what you were thinking. Any solid link will work just fine in the rear, or make your own out of 1/2"x20 threaded rod and LH and RH threaded Heim joints as I did.
Jerry Bransford is offline
post #5 of 8 Old 04-18-2007, 11:39 PM
McLovin
Thats an interesting idea. Do you feel like the hiems have allowed more rear end travel? How big of hiems did you use?
That was inventive
McLovin is offline
post #6 of 8 Old 04-18-2007, 11:45 PM
Jerry Bransford
Administrator
Since the threaded rod was 1/2"x20, matching 1/2"x20 threaded Heims worked pretty well.
post #7 of 8 Old 04-22-2007, 12:37 PM Thread Starter
CHRRRIS
CHRRRIS's Avatar
Anybody else hear this?
If that's not true, would I want to get front links too?
-Henry Ward Beecher
CHRRRIS is offline
post #8 of 8 Old 04-22-2007, 01:40 PM
McLovin
If you don't get front links with your lift you'll end up breaking the stock ones sooner or later. You should really get the rear ones as well. But most lift kits come with them....
McLovin is offline
Extended Rear Swaybar Links Needed for OME? kubwa_jim JK Wrangler Technical Forum 5 02-02-2010 07:26 PM
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 12:18 PM
rear sway bar extended links safarimike TJ Wrangler Technical Forum 2 07-07-2008 10:04 AM
Sway Bar Extended End Links DixiesCJ3B TJ Wrangler Technical Forum 1 02-19-2008 11:55 AM
Extended front sway bar links newbomb TJ Wrangler Technical Forum 5 09-04-2005 08:10 PM
