Rear Engine Coolant Leak :( - JeepForum.com
post #1 of 7 Old 12-05-2010, 02:04 PM Thread Starter
MrMiyagi
Hey guys,
I have a 2006 4.0L TJ that's developed a coolant leak. There is a steady drip that's coming off between where the rear engine and tranny meet, but I can't pinpoint where the hell it's coming from as the space is too tight. Anyone have ideas or a link to a diagram to help me pinpoint where to look? I've heard there are two freezer plugs in the back? Not sure if there is coolant hosing or another part back there that might be the source of the leak.
Hopefully it's nothing serious like a cracked block or something?
I'm going to a buddy's garage for him to try to take a look, possibly pull the engine to get a better view. But any additional ideas would help.
Thanks,
MrMiyagi is offline
post #2 of 7 Old 12-05-2010, 02:43 PM
1222
RIP John
1222's Avatar
Get one of those little round mirrors that are attached to a telescoping rod. You can put in tight places and with the help of a flashlight shinning onto the mirror perhaps you can see the leak.
(2011-2016)
1222 is offline
post #3 of 7 Old 12-05-2010, 03:45 PM
fishinjeeper
My guess is a hose going to or from the heater core
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #4 of 7 Old 12-05-2010, 03:54 PM
4.0l sahara
There is a freeze plug on the back of the head.
4.0l sahara is offline
post #5 of 7 Old 12-05-2010, 07:37 PM
Curly5759
It does sound like a freeze plug to me. Before you start the repair, make darn sure it is not a heater hose or something else up top leaking down.
You can take it to a shop and ask them to pressure test the cooling system, that will help pinpoint the leak.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
post #6 of 7 Old 12-05-2010, 08:31 PM
chris142
Whats the rest of the cooling system look like? I can't imagine a 4 yr old engine being so badly rusted that it ate a freeze plug already.
I'd take a good look at the heater hoses before tearing the Jeep apart to replace freeze plugs.
chris142 is offline
post #7 of 7 Old 12-05-2010, 11:24 PM
mightydog78
probably the freeze plug
mine blew out on the highway covering the car behind me (he was tailgating) in coolant, got what he deserved
may wanna get it looked at so it doesnt blow!
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
antifreeze , coolant , engine , leak
I see coolant I smell Coolant But can't find leak. MrB TJ Wrangler Technical Forum 23 07-18-2010 06:33 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 09:24 AM
Coolant leak from the back of the engine, 4cyl. Omning TJ Wrangler Technical Forum 4 09-04-2009 07:15 PM
Engine coolant leak? flexsaharatj TJ Wrangler Technical Forum 20 04-13-2009 11:36 PM
Rear block coolant leak? jmp1177 TJ Wrangler Technical Forum 9 12-27-2008 10:26 AM
