Rear end problems!!! Need help!!! - JeepForum.com
post #1 of 40 Old 03-02-2012, 12:45 PM Thread Starter
ACB2010
First off, I have an 01 wrangler sahara edition with the dana 44 rear axle and 30 front axle. I have a 4" rough country lift 3" body (wish I didn't don't give me hell). There is a popping sounds like metal hitting coming from my rear end so first of all I checked the track bar and it was loose so i tightened it up, did not stop next i noticed a bushing in my lower control arm was loose so i fixed that still no help. I also just had all my lift tightened because I thought that might be causeing it but still no help. It does the noise in turns and reverse and im completly out of things I know how to check? I also replaced axle shaft and u joint in the last year and I dont believe it is a wheel bearing!
01 White jeep sahara, black rhino lined hardtop, 4" suspension, 3" body, 35" MTZ, Front tube fenders, roof rack, 3% tint around 28% on windshield, two 10's probox
ACB2010 is offline
post #2 of 40 Old 03-02-2012, 01:34 PM Thread Starter
ACB2010
bump
ACB2010 is offline
post #3 of 40 Old 03-02-2012, 01:36 PM
STIFLER
when do you hear it? normal driving or articulation? drive shaft checks out?
edit: NVM I see when turning or reverse
0311/2531 USMC YUT
STIFLER is offline
post #4 of 40 Old 03-02-2012, 01:38 PM Thread Starter
ACB2010
well since everybody knows what mcdonalds is when I go threw there drive through It pops all the all the way starting from when I turn til I complete the turn and everybody looks at me as if I have lost my axle
ACB2010 is offline
post #5 of 40 Old 03-02-2012, 01:42 PM
TanTJ04
Check for any movement in the lower control arm bushings. Rough Country rubber bushings dont hold very long.
Originally Posted by chriswj View Post
The 4.0 is like that fat guy who will eat mac and cheese that has been on the stove for three days; eats it and wont look back!
2004 TJ X 5spd, 30-Aussie locker and Chromo'd, 44-lsd & disc brakes, 4" Currie lift, Anti-rock, 1.25" bl, UCF 1" skid & Lo-pro mount, AA SYE, JKS MML, ZJ V8 Tierod, JKS Trackbars, smittybuilt winch w/ synthetic line, Caravan fuel injectors, CAI, TB spacer, flowmaster 44 2.5", 35x12.50x15 km2, 7" fenders, uniden cb
TanTJ04 is offline
post #6 of 40 Old 03-02-2012, 01:43 PM
grnsporty
Probably your spider gears. Pull the diff cover and check them out. If their bad I have a dana 44 Trac loc with 4 k on it for cheap if interested.
grnsporty is offline
post #7 of 40 Old 03-02-2012, 01:46 PM Thread Starter
ACB2010
That was checked and one of my bushings was def. worn out so I ordered a new one and installed it thinking I finally figured it out and Pop goes the weisel
ACB2010 is offline
post #8 of 40 Old 03-02-2012, 01:48 PM Thread Starter
ACB2010
okay spider gears are next will be checking those this weekend! what all will need to be done in changing those can the moderate home mechanic do that?
ACB2010 is offline
post #9 of 40 Old 03-02-2012, 02:15 PM
grnsporty
Yea its easy. Look up how to install a Aussie locker. It will give you directions.
post #10 of 40 Old 03-02-2012, 07:09 PM Thread Starter
ACB2010
Any other suggestions I have sometimes this weekend and want to know what all I should check and how to check it if possible I know there are a pretty good bit of people with this problem and I've searched and can't find any answers so I'm sure this will help alot of jeepers!
ACB2010 is offline
post #11 of 40 Old 03-02-2012, 07:12 PM
biffgnar
biffgnar's Avatar
I'd recommend taking your time on the weekend to learn about punctuation.
biffgnar is offline
post #12 of 40 Old 03-02-2012, 07:25 PM
RaggedOleMan
First thought is broken trac-bar bracket, or worn TB bushing. Check both ends.
Second thought is worn out control arm bushing(s). There's 8 back there.
Third is broken tranny mount.
Fourth is loose pinion nut
Fifth is worn or broken motor mount.
Loose body mount comes to mind, too. You have a 3" body lift? Trash/sell it, and put in a 1" - 1/4" body lift...
RaggedOleMan is offline
post #13 of 40 Old 03-02-2012, 07:27 PM
Sundowner
You bring up a good point...there's still too much left unchecked. I'd go over the thing with a fine-toothed comb.
Oh, and OP, about that body lift...I know you said not to give you hell, but, well...f*** that noise. GET RID OF THE 3" BODY LIFT!!!
Sundowner is offline
post #14 of 40 Old 03-02-2012, 07:52 PM Thread Starter
ACB2010
Well first off im going to ignore the comment about punctuation its the internet and a forum at that? Really who cares? Your comment did not help anyone so thanks! Secondly, thank you for the real advice I will be going down that list as soon as possible and update everyone on what I find. Maybe this will help others in the future. Also body lift will go when money is available unless someone wants to donate a 6" longarm
ACB2010 is offline
post #15 of 40 Old 03-02-2012, 07:56 PM
TanTJ04
Also, it may sound dumb but check ur lugnuts. They make strange sounds when loose.
TanTJ04 is offline
dana44 , help needed , rear end noise , suspension lift , tj
97 TJ rear end problems Nberry90 TJ Wrangler Technical Forum 4 02-12-2012 03:13 PM
rear end problems AJM YJ Wrangler Technical Forum 2 04-07-2011 07:48 PM
rear end problems ionakana YJ Wrangler Technical Forum 1 06-23-2009 04:10 PM
Rear End Problems? 01blackws6 YJ Wrangler Technical Forum 12 11-17-2008 10:54 AM
rear end problems YJ4x4on35'z YJ Wrangler Technical Forum 2 08-29-2003 06:10 AM
