-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Rear end problems!!! Need help!!! (http://www.jeepforum.com/forum/f9/rear-end-problems-need-help-1337103/)
ACB2010 03-02-2012 12:45 PM
First off, I have an 01 wrangler sahara edition with the dana 44 rear axle and 30 front axle. I have a 4" rough country lift 3" body (wish I didn't don't give me hell). There is a popping sounds like metal hitting coming from my rear end so first of all I checked the track bar and it was loose so i tightened it up, did not stop next i noticed a bushing in my lower control arm was loose so i fixed that still no help. I also just had all my lift tightened because I thought that might be causeing it but still no help. It does the noise in turns and reverse and im completly out of things I know how to check? I also replaced axle shaft and u joint in the last year and I dont believe it is a wheel bearing!:confused::confused::confused::confused:
ACB2010 03-02-2012 01:34 PM
bump:confused:
STIFLER 03-02-2012 01:36 PM
when do you hear it? normal driving or articulation? drive shaft checks out?
edit: NVM I see when turning or reverse
ACB2010 03-02-2012 01:38 PM
well since everybody knows what mcdonalds is when I go threw there drive through It pops all the all the way starting from when I turn til I complete the turn and everybody looks at me as if I have lost my axle:o
TanTJ04 03-02-2012 01:42 PM
Check for any movement in the lower control arm bushings. Rough Country rubber bushings dont hold very long. :thumbsup:
grnsporty 03-02-2012 01:43 PM
Probably your spider gears. Pull the diff cover and check them out. If their bad I have a dana 44 Trac loc with 4 k on it for cheap if interested.
ACB2010 03-02-2012 01:46 PM
That was checked and one of my bushings was def. worn out so I ordered a new one and installed it thinking I finally figured it out and Pop goes the weisel:(
ACB2010 03-02-2012 01:48 PM
okay spider gears are next will be checking those this weekend! what all will need to be done in changing those can the moderate home mechanic do that?:cool:
grnsporty 03-02-2012 02:15 PM
Yea its easy. Look up how to install a Aussie locker. It will give you directions.
ACB2010 03-02-2012 07:09 PM
Any other suggestions I have sometimes this weekend and want to know what all I should check and how to check it if possible I know there are a pretty good bit of people with this problem and I've searched and can't find any answers so I'm sure this will help alot of jeepers!
biffgnar 03-02-2012 07:12 PM
22 Attachment(s)
I'd recommend taking your time on the weekend to learn about punctuation.
RaggedOleMan 03-02-2012 07:25 PM
First thought is broken trac-bar bracket, or worn TB bushing. Check both ends.
Second thought is worn out control arm bushing(s). There's 8 back there.
Third is broken tranny mount.
Fourth is loose pinion nut
Fifth is worn or broken motor mount.
Loose body mount comes to mind, too. You have a 3" body lift? Trash/sell it, and put in a 1" - 1/4" body lift...
Sundowner 03-02-2012 07:27 PM
You bring up a good point...there's still too much left unchecked. I'd go over the thing with a fine-toothed comb.
Oh, and OP, about that body lift...I know you said not to give you hell, but, well...f*** that noise. GET RID OF THE 3" BODY LIFT!!! :mad:
ACB2010 03-02-2012 07:52 PM
Well first off im going to ignore the comment about punctuation its the internet and a forum at that? Really who cares? Your comment did not help anyone so thanks! Secondly, thank you for the real advice I will be going down that list as soon as possible and update everyone on what I find. Maybe this will help others in the future. Also body lift will go when money is available unless someone wants to donate a 6" longarm
TanTJ04 03-02-2012 07:56 PM
Also, it may sound dumb but check ur lugnuts. They make strange sounds when loose.
The time now is 07:14 PM.
