Rear end hops on first acceleration. Coil Springs - JeepForum.com
post #1 of 4 Old 07-28-2010, 08:36 PM Thread Starter
Trueblood
This has been plaguing me for the last month now, every time i start off letting out the clutch on my jeep TJ Wrangler the rear end seems to hop. I recently did a v8 swap and had no problems but its been starting to get more noticeable. I have a Detroit Tru Track locker in the rear end also a 4 inch lift with a 1 inch body lift. I do not have a slip yoke eliminator which could be the problem but the Drive line isn't at to extreme of an angle. I went ahead and pulled the rear drive line and drove in 4 wheel drive around the neighborhood to see if the problem was in the clutch, etc.. but it only happens with the rear drive line hooked up. I also replaced the u joints in the rear drive line as well but to no avail. Any ideas guys? I am at a loss
Trueblood is offline
post #2 of 4 Old 07-28-2010, 08:39 PM
casperbrown
1993 XJ Cherokee
u might have play "broken/compressed etc. teeth" in your real diff.
just an idea.......
casperbrown is offline
post #3 of 4 Old 07-28-2010, 08:49 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
hook up your rear shaft and install a Tcase drop kit or add washers between your frame and skid. if your problem is u joint bind [which i think is your problem] this will tell you if it is or not.
after you drop the Tcase and drive around, if you dont have any vibes, then it is time for a SYE and CV shaft.
if you still have vibes, you have other problems.
give this a try and report back.
Mail crawling.
MisfitSeven is offline
post #4 of 4 Old 07-28-2010, 08:54 PM Thread Starter
Trueblood
Thanks for the quick replys. Ill look into these thanks
rear , hops , vibrations , driveshaft , vibes
Do rear coil springs have a top or bottom? johnxjeep TJ Wrangler Technical Forum 3 07-17-2010 08:39 AM
Is there a top or bottom to my rear coil springs? stangman68inftc TJ Wrangler Technical Forum 0 01-30-2009 05:05 PM
Rear Coil Springs zener6 TJ Wrangler Technical Forum 2 10-14-2008 01:03 PM
Rear Coil Springs Bhirst TJ Wrangler Technical Forum 11 03-14-2007 09:24 PM
Coil springs damaging rear shocks? flsar TJ Wrangler Technical Forum 1 09-08-2001 08:58 AM
