Rear drum issue... wearing weird. - JeepForum.com
post #1 of 6 Old 05-12-2013, 03:29 AM Thread Starter
Maverickxeo
I dont have any pictures; first of all, so I will describe whats happened.
I replaced the drums and shoes at the same time; with the hardware as well on my 02 TJ sport, with the Dana 44 rear end.
Ive had some squealing; which I determined was the passenger side rear drum, so Ive pulled it off, and inspected it... seemed fine. I do have the E brake set properly as well, before anyone mentions that.
I pulled the drum off again tonight (because the squealing is driving me insane) and I see that the shoes have a 'bump' down the entire length of them, and the drum has a 'groove' all around it, where the shoes' 'bump' has been wearing it down.
Now, I am not sure what to do. The brakes are still fine (still not excessively worn) but that groove and bump have me concerned. They were NOT there when the new parts were installed; or on the old shoes and drums. The new driver's side is perfectly fine; smooth and even wear.
I guess I am wondering if the squeal is a result or cause of the odd wear; and if I could 'fix' this cheaply. Worst case scenario, I replace the shoes and the drum (I DO have another set of shoes; Id need to buy a new drum though), but Id rather save those for the next time I need to do brakes.
EDIT: The brake squealing IS coming from that drum. I took off the drum and shoe; there was no squealing with the vehicle in the air, in 4wd and in gear. As soon as I put the drum back on; then the squeal started again.
So, is there anyway to quiet it down? The shoes/drum are literally a few months old...
Maverickxeo is offline
post #2 of 6 Old 05-12-2013, 09:17 AM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
Did you adjust them properly?
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #3 of 6 Old 05-12-2013, 11:02 AM Thread Starter
Maverickxeo
I was sure I did. I spent a lot of time setting them; and had my father help me out.
post #4 of 6 Old 05-12-2013, 12:06 PM Thread Starter
Maverickxeo
Well I showed my dad the wear today... he figures its odd; but probably because there was a rock or some debris in there.
The squealing is from them being set too tight, he figures (I guess when we set them, we had them too tight). Hes getting old; so maybe he forgot how to properly set them.
post #5 of 6 Old 05-12-2013, 12:59 PM
TheBoogieman
Devil's Advocate
Blame it on good ol dad.
post #6 of 6 Old 05-12-2013, 02:36 PM Thread Starter
Maverickxeo
He likes to take over on jobs... I just watch when he comes in.
Anyways, the actual problem was that the self adjuster came off and was rubbing the bottom of the drum. We fixed it and it should be good now (after taking off the drum a few times; its finally fixed hopefully haha).
I guess its a simple mistake that we both made since neither of us noticed it in the many times weve inspected it.
