Rear drum to disc brake swap!!! - JeepForum.com
post #1 of 6 Old 07-21-2010, 05:12 AM Thread Starter
TeeJay00
Well one of the items on my next to do list is to swap my rear drum brakes to discs!!!
Any writeups on this??? What are the required parts???
TeeJay00 is offline
post #2 of 6 Old 07-21-2010, 05:30 AM
rocko-n-miss
I've done a little bit of research on this myself, But I'm also looking at swapping my rear to an 8.8 from an explorer, 97 or later comes with disc already, the proportioning valve from the Rubicon will work just fine for this, then your looking at break lines, I haven't got in to it enough yet to tell you if you could grab the brake assy from the 8.8 and make it work??? not sure. By the end of summer I should be starting my build thread and it will be a part of it, don't know how long your time frame is, but by the end of next month I'll be one happy man in my garage, with parts spread every where! Best of luck to ya!
2003 TJ, 1" body, 33X12.5 Swamper IROK's, Rampage top,
rocko-n-miss is offline
post #3 of 6 Old 07-21-2010, 05:36 AM Thread Starter
TeeJay00
I was planning on pulling the rear discs off an '03+ from the a junkyard... I don't think it would be that hard to swap then. But I need to know what should I be replacing.
Oh and on the subject of you working on your build... Another difference between there and here!!! You wheel in the summer and work on your cars during winter... We do (or have to do) the exact opposite here.
TeeJay00 is offline
post #4 of 6 Old 07-21-2010, 05:40 AM
gixxerphil
check this site
Disc Brake Conversion - 1
Originally Posted by elephantrider View Post
can you get a good pic of your muff set up ?
gixxerphil is offline
post #5 of 6 Old 07-21-2010, 05:45 AM
rocko-n-miss
Aww just saw your location! I do both, it just happens that this is when I'm going to have sometime to work on it, one of my jobs is Marine Salvage, we do alot of work in the Gulf of Mexico, there is a ton of down time in the winter due to un favorable conditions! Hard for a diver to do in water decompression while the vessels is bobbing 10-15 feet due to swells, lol!
post #6 of 6 Old 07-21-2010, 12:19 PM
tjdriver
i got my disc brakes from a zj. i picked up a whole rearend for 250 from a local junkyard and swapped everything over.
tjdriver is offline
drum brake , rear , disc brake , swap , tj , wrangler , write-up , write up
Best Rear drum to disc brake conversion TJ grebva3 TJ Wrangler Technical Forum 74 09-04-2014 06:04 AM
Dana 44 rear drum to disc swap TJBEEBOB TJ Wrangler Technical Forum 22 04-25-2013 11:18 AM
Disc Brake Swap to Rear JeepDoo TJ Wrangler Technical Forum 3 05-06-2009 07:55 AM
Rear Drum Brake To Disc Conversion 1bdmudr YJ Wrangler Technical Forum 1 01-15-2009 06:53 PM
4-Wheel-Disc vs Front-Disc, Rear-Drum... thejafe TJ Wrangler Technical Forum 17 11-24-2003 07:36 PM
