Rear driveshaft won't line up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear driveshaft won't line up
Unread 03-08-2013, 11:44 AM   #1
rt4422
rt4422's Avatar
I removed my rear driveshaft to replace a u joint and centering yoke ball and now I'm trying to put it back in. Is there some sort of trick for this? I can't seem to get both lined back up. I have an SYE if that changes anything. Thanks
So that's in fine...
And that's like a half rotation off....
rt4422 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 11:47 AM   #2
CrawlingForward
If you chock your wheels and put the transmission in neutral (or the transfer case), you can rotate the TC pinion to make it line up.
My Other Jeep Is A Jeep - Crawlingforward's Jeep-Related Adventures
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
- North Shore Jeep Club -
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 12:01 PM   #3
biffgnar
biffgnar's Avatar
Or jack up a rear tire and rotate the rear pinion?
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 12:10 PM   #4
rt4422
rt4422's Avatar
Sorry guys, brain fart. I still had it in 4wd so I couldn't rotate the transmission side.....
Unread 03-08-2013, 12:51 PM   #5
sdptrey
wow must have been a rough day. everyone does now and then
sdptrey is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 12:51 PM   #6
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
It's ok we have all done it. Just not many post it LOL
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 03:24 PM   #7
clg82
I have a quick question whilst we're on the subject of the rear driveshaft...I have a rear tom woods double cardan shaft with SSSYE and I noticed that you don't run a boot on your rear driveshaft....any reason for that?
clg82 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 04:38 PM   #8
BLK00TJ
There's two basic styles to TW shafts. One with a zerk fitting and no boot and the other with boot and no zerk
BLK00TJ is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 04:42 PM   #9
clg82
The one without the boot has grease internally than as opposed to the one with the boot?
"I'm Hotshot, the worlds best wheeler, but I don't even know how to change out a U-Joint"
Unread 03-08-2013, 04:47 PM   #10
BLK00TJ
From the TW site:
"With the XB configuration, we will use a heavy rubber boot which is banded down with stainless steel banding to seal all of the contaminates out and keep the grease in. The XC configuration uses the same slip yoke & spline stub but instead of using the rubber boot, we drill and tap the slip yoke for a grease fitting and use a dust cap which has convolutions that follow the spline stub for sealing. We consider the XB configuration to be the longest lasting and best value."
